R50/53 Power Steering Pump whines while not turning
Old Sep 11, 2024 | 05:02 AM
jarred byers's Avatar
jarred byers
Hi all,
I am hoping for some insight/advice. My 2006 MCS with 113k miles recently developed an issue with the PSP. Unfortunately the car is not covered under the recall. Intermittently, the pump would whine way louder than normal upon start up but quiet down after about a minute. Fluid level was fine, power steering was normal, and pump would turn off and on with the car. I proceeded to disassemble the pump, clean the dust buildup out, add new grease to the bearings in the pump, and reinstalled. I also changed the fluid reservoir and added new correct fluid. Now my issue is that I can slightly hear the pump whine even when not turning the wheel. Again, steering is nice and light and no other issues with the pump. Does anybody have any suggestions as to what's happening and if I should be concerned?
Old Sep 11, 2024 | 12:48 PM
mrbean's Avatar
mrbean
The pump is inherently noisy, you're never going to make the noise go away completely.
I would carry on as if nothing is wrong.
Old Sep 11, 2024 | 06:48 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
they get louder as the bearings wear out. i've had a few fail and mine have all been bearings that got louder and louder until they were impossible to ignore any longer
Old Sep 12, 2024 | 08:26 AM
jarred byers
Thank you both! I will just drive on as normal and should it fail or get louder, so be it.
Kazukins
Nov 25, 2021 12:12 PM
Thumper Simpson
May 1, 2017 04:59 PM
Ninopr
Cooper (non S)
Jan 1, 2013 07:41 PM
jgLabrown
Nov 25, 2009 10:06 AM
jso123
48
Feb 20, 2009 02:43 PM
