R50/53 Changed Axle now getting 4 warning lights
Old 05-24-2024, 01:00 PM
phildb4's Avatar
phildb4
phildb4 is offline
Recently changed the left front axle. Everything seems to fit and car drives...however I am now getting 4 yellow dash warning lights...ABS, Tire Warning, Stability (traction) Control, and Brake Pad lights. I have tried to cancel these lights as recommended, first disconnecting the battery (for 30+ minutes), then going thru the procedure of holding down speedo reset button, turning key to #1 position.....etc...etc. At the final step, the speedo made some noise, and the indicator jumped slightly as per the instructions...but the lights remain on.
I thought perhaps I messed up the ABS sensor....but open to suggestions why the lights came on after replacing the axle.
The car is a 2004 R53 that I have owned since new with about 114,000 fun miles
Old 05-24-2024, 01:59 PM
Jason Cornelius's Avatar
Jason Cornelius
Jason Cornelius is offline
You either broke or unplugged the abs sensor on that axle. Scan tool and live data are your friend on this, live data will tell you which wheel, but seeing how you know where work was done last, buying a new sensor and replacing it will be your best bet. I used the Bosch ones for the front,
Amazon Amazon
, had to go OEM on rear.
Here2Go (05-30-2024)
Old 05-24-2024, 05:53 PM
MCS4FUN's Avatar
MCS4FUN
MCS4FUN is online now
Wow, original owner 20 years yet this being your first post on NAM. Not meant as criticism but instead, missed out on sage advice such as Jason shared. I've learned so much more about my own R53 (and former R56) here, augmented by various specialist YouTube videos. Congrats on your long-term ownership - perhaps stick around and share related experiences!
Old 05-30-2024, 01:51 PM
phildb4's Avatar
phildb4
phildb4 is offline
I replaced the ABS sensor and still getting multiple warning lights. I used the procedure of pushing speedo reset button as instructed..even got the speedo to make a noise and the pointer wiggled. Also have gas cap warning light, but have not had a chance to replace the cap yet. I added air to tires to specification, as the tire light was one of the lights that stay on. Anything else I should be trying?Thanks in advance.
Old 05-30-2024, 03:24 PM
Here2Go's Avatar
Here2Go
Here2Go is online now
NAM Community Team
IMO - Plain and simple - I would advise you to purchase a good OBDII scanner. They are an invaluable if not indispensable investment and can save you a lot of guess work/headaches.
A good BMW/Mini scanner/reader can/will identify the codes and allow you to clear them. The speeedo "reset" button is really only good for a few minor things like resetting oil and maybe brake change intervals.
Let us know if you are able to resolve the issues
Old 05-31-2024, 08:09 AM
ECSTuning is online now
Received 2,004 Likes on 1,800 Posts
ABS sensor for sure. Sometimes the sensors i have seen come loose if not installed all the way and wrap themselves around the axle. If its on the one side it pulls the brake pad sensor with it.
Old 06-02-2024, 11:28 PM
JackPrice's Avatar
JackPrice
JackPrice is offline
Same here, I also received warning many times.
Old 06-04-2024, 10:27 AM
phildb4's Avatar
phildb4
phildb4 is offline
Any recommendations for a good Mini OBD scanner.??
Old 06-04-2024, 01:58 PM
Here2Go's Avatar
Here2Go
NAM Community Team
I wouldn't say this would be my recommendation due to the current state of inflated prices -
But I really like my Foxwell NT510 Elite BMW/Mini OBDII scanner. For me - It does all that I/my Mini needs...
I bought specifically to extinguish my airbag light after preforming the "airbag battery squib bypass fix" about 2wo years ago. Purchased off eBay, brand new in the box for $115.
I think it retailed for $160 back then. (Amazon now lists $180+)...
Prices have gone crazy lately with OBDII scanners but you can still find a reasonable deal (for the right one) if you shop around. Others will chime in with their trusted recommendation.
Just be sure it is BMW MINI specific or has the Mini software preloaded - to save yourself some headaches.
With that being said; avoid buying a "general purpose" scanner. Chances are it might not have the ability or features to dig into the Mini computer to read/diagnose some important fault codes.
Check ECS Tuning, Pelican parts, FCP euro websites for Mini specific parts.
fleBay may still be a good source for a better deal.
On a side note: My first OBDII scanner was a Creator C110 (not recommended). It did have some MINI diagnostic ability but for $80 - it was just about useless.
Old 06-04-2024, 04:36 PM
noodlesandsam's Avatar
noodlesandsam
noodlesandsam is offline
This will also tell you which sensor is bad. FYI - I had to replace the left front bearing - it ruined abs sensors. If your bearing is bad and makes contact with the sensor, then you are done. Any debris on rhe back side of the bearing could come into contact.
Old 06-04-2024, 04:58 PM
Jason Cornelius
I carry the schwaben from ECS in the Mini. If you watch they run deals all the time, I got mine shipped for $150ish
ECSTuning (06-05-2024)
SkipII
02-20-2024 07:06 AM
mikejano
07-05-2014 11:10 AM
blue agave
07-03-2008 04:24 PM
mini coopS
01-11-2007 10:25 AM
Quick Reply: R50/53 Changed Axle now getting 4 warning lights
