R50/53 PFL owners (pre face lift) Need info on revs
Old Apr 12, 2024 | 07:36 PM
SD200's Avatar
SD200
I just picked up my 5th mini, A really clean 05 S in pepper white. It is quite buzzy on the highway and was thinking about a PFL trans (or CWP)
But what I would like to know from PFL owners is what speed are you doing at 3000 RPM in 6th?
I think it best to use a GPS so tire/ wheel size does not fudge the equation.
On my 2005 I am doing 66.7 MPH at 3000 RPM
If this is a significant difference I am considering a PFL box when I do the clutch at some point.
Why oh why did mini not put a OD 6th in the car I will never know.
Thanks,
Old Apr 12, 2024 | 10:28 PM
deepgrey's Avatar
deepgrey
This should have everything you need to calculate speed and RPM.
Are you running a stock height tire? That seems slow for 3k RPM.
Old Apr 13, 2024 | 07:27 AM
mrbean's Avatar
mrbean
Your speed/rpm matches perfectly with the trans ratios deepgrey posted the link to (assuming stock tire sizes).
My PFL ('03 MCS 6MT) also seem close to those calculations (70 mph @ 3000).
You'll notice the difference in 6th gear ratios between pre/post FL is very small (4.7%, or about 2 mph @ 3k rpm). So you're not going to accomplish much in this regard if you swap the trans.
IIRC correctly, there were some complaints that 1st gear was too tall on PFL cars which supposedly prompted the gear ratio changes. So the difference is most noticeable in lower gears / speeds (if you do the math, you'll see there's a greater percentage difference in the lower gears than the higher gears).
Old Apr 13, 2024 | 09:30 AM
deepgrey's Avatar
deepgrey
Hmm. I thought I calculated a couple of mph higher for the facelift trans (closer to 69 mph), but maybe I got a tire size or something a bit wrong. Not that I have much experience with the R53.
I do know the numbers match perfectly for my car with my tire size (which isn’t terribly relevant to this discussion). I’m spinning ~3950 rpm at 80 mph.
Old Apr 13, 2024 | 07:34 PM
SD200's Avatar
SD200
Thanks all and so much for that then, would be nice to have a nice OD top as I doubt many are pulling max revs in 6th anywhere but elkhart lake!
Old Apr 13, 2024 | 07:59 PM
deepgrey's Avatar
deepgrey
Ain’t nobody pulling max revs in 6th with an R53 that’s anywhere close to stock .
Old Apr 14, 2024 | 04:38 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Fashionably late to the soiree as usual -
'04 prefaceift R53 manual, 17" S-lites, 15% SC pulley,
As noted above: 6th gear, 70mph @3,000rpms
2nd gear, 70mph, @5,800rpms - time to shift!
imaslowdriver
Aug 12, 2019 07:26 AM
pmsummer
R55 :: Clubman Talk (2008+)
17
Aug 24, 2012 05:15 PM
hcallaway
Jun 29, 2005 07:52 PM
TUFFMINI
May 3, 2005 09:04 PM
cincymcs
Feb 7, 2005 07:35 AM
