R50/53 Rough BPV Close?
Rough BPV Close?
Hello! My R53 recently had the supercharger serviced. I changed the oil, water pump, thermostat, and got an OEM BPV.
When slowing down, around 1K rpm, the car will jolt a bit uncomfortably. I believe it’s when the bypass valve closes.
Can anyone shed light on this? Is this a characteristic of the car? Can I do anything to help it?
Thank you.
Thank you.
Just curious did you do the work yourself or hire a garage? Please don't say the Stealership...
Any OBD2 codes at this point? Good rundown of BPV failure diagnosis and replacement:
tragedybysyntax
81
Sep 4, 2014 06:08 AM
