R50/53 Heater Core Shut-off Valve
Old Oct 14, 2022 | 11:15 PM
cut7's Avatar
cut7
Has anyone installed a heater shut-off valve (meaning a valve that shuts of the water going to the heater core). I notice my right foot getting a bit warm & I figure shutting off the water to the core would cool it down a bit; & also make the A/C more efficient. Installing the valve is easy enough; just put it inline on the feed side of the heater core. But how to actuate it? My Ford truck has a shut-off valve that is vacuum operated; I'm just trying to figure out how to trigger it. Is the blend door vacuum operated? Or is it an electric servo motor? If it's vacuum operated, I could tee into that to shut off the water to the core.
Any ideas?
Old Oct 15, 2022 | 12:59 AM
A383Wing's Avatar
A383Wing
There are cable operated shut off valves out there... install one of those and put a universal choke pull cable under the dash somewhere
Bryan
Old Oct 15, 2022 | 11:49 AM
cut7's Avatar
cut7
Bryan
I'd rather do it automatically. Does anyone know if the blend door is actuated by vacuum or servo motor? The Ford valve would work beautifully if the climate control is vacuum operated.
Old Oct 15, 2022 | 11:55 AM
A383Wing's Avatar
A383Wing
if your car has automatic AC/heat system, the doors are operated by servo motors....if your car has the manual 3-**** style heater controls.....pretty sure those are operated by levers and possibly cables....
Fairly certain that vacuum operated systems we not in our cars...I don't see any reference to vacuum controlled items in the service manual
Bryan
Old Oct 15, 2022 | 12:00 PM
cut7's Avatar
cut7
I think you may be correct. My car has climate control, so I may look for a heater valve that is servo operated. Either that, or get an electrically operated vacuum valve & have that actuate the Ford heater valve.
Old Oct 17, 2022 | 10:38 AM
ssoliman's Avatar
ssoliman
There is a mix door for the air flow, not water.
w auto AC, controlled by servo
w manual, controlled by cable
located behind glove box
Old Oct 17, 2022 | 10:46 AM
cut7's Avatar
cut7
I know there is no water valve; that's what I'm talking about retrofitting one. What I'm looking for is useful information as to how to control the retrofitted valve.
Old Oct 17, 2022 | 06:50 PM
dmath's Avatar
dmath
Did the location change with the facelift? In my 2003, the blend door is on the left side of the right footwell. The recirc control motor is behind the glove box.
Old Oct 18, 2022 | 10:26 AM
ssoliman's Avatar
ssoliman
you’re right, left side. Glove box needs to come off
Trippy
May 20, 2025 03:08 AM
IndieJoe
Mar 26, 2017 12:30 PM
ViVi^BoY
Nov 3, 2007 10:46 PM
o-ron
Aug 9, 2006 01:08 PM
