R50/53 flat tow r50 with a cvt trans
Hi guys. Question - is it OK to flat tow a CVT mini for a few miles at moderate speeds? I picked up a cvt project car with a slipping trans that may have been towed this way about 10 miles the PO says. Also, is there a fuse somewhere I could pull to disable automatic locking? I find that feature annoying. Cheers, Ron
Of course a project car is unlikely to have an owners manual.
Absent some high confidence info that flat towing the car with the CVT is ok, my advice would be to err on the side of caution and arrange to flat bed the car from A to B.
(I would expect the CVT to be the same in this towing business as a standard automatic and a dual clutch automatic. The engine spinning the input shaft drives the transmission oil pump.)
My standard response is better safe than sorry and to not risk auto/CVT damage towing the car with the drive wheels on the ground even if the transmission is in neutral.
Jackbrews
Oct 12, 2021 07:37 PM
R50/53 Do I have the dreaded CVT?
Raster Burn
Aug 13, 2009 01:35 PM
