R50/53 HELP! Temp gauge shoots up to red after start.
Old Aug 30, 2022 | 06:39 PM
kemz562's Avatar
kemz562
Hey guys, first post ever because I’m having issues with the temp gauge reading hot right after turning the car on. The car is cold, but is reading hot. Also the fan and power steering fan stay on and won’t turn off until I unplug the battery. I did a whole clutch removal and change all the parts on the sub frame, along with supercharge fluid change. There is a hose that is leaking pretty bad too and will be replacing tomorrow, but would that be a reason to immediately shoot to red before it had time to warm up? Not enough coolant in the system causing this? Thermostat issue?
Old Aug 30, 2022 | 07:01 PM
dmath's Avatar
dmath
If it's reading hot *immediately* after starting, I don't think that could be the thermostat. Maybe the temperature sensor?
Old Aug 30, 2022 | 07:12 PM
kemz562's Avatar
kemz562
Do you know where the temperature sensor is located on a 2002 Mini Cooper r53? I was looking earlier and had no luck.
Old Aug 30, 2022 | 07:25 PM
ghostwrench's Avatar
ghostwrench
It's on the back (transmission side) of the cylinder head, just beneath the thermostat housing, I believe.
Old Aug 30, 2022 | 07:26 PM
dmath's Avatar
dmath
It's in the cylinder head behind the thermostat housing.
Edit:@ghostwrench beat me to it.
Old Aug 30, 2022 | 07:30 PM
dmath's Avatar
dmath
See this page on realoem:
https://www.realoem.com/bmw/enUS/sho...diagId=11_3086
Old Aug 30, 2022 | 07:37 PM
kemz562's Avatar
kemz562
Thanks guys for the information. I’m going to go check it out, maybe I forgot to plug it in. The car was fine before beside leaking from the hoses causing air to get trapped inside the system.
Old Aug 30, 2022 | 07:51 PM
kemz562's Avatar
kemz562
I just check right now and it was unplugged. I either forgot to plug it in or it came loose. Thanks so much! I’m going to have to take the air box out to plug it in, so Ima just change the thermostat while I’m at it!
APL
Sep 26, 2018 08:13 AM
roll14me
Jul 8, 2014 07:07 AM
Dunmisk
Jun 12, 2010 11:43 AM
Z06C5R
Jan 31, 2010 12:28 PM
sharpie
Jan 13, 2010 11:24 PM
