R50/53 Aircon issues
Old Jun 29, 2022 | 06:34 PM
SkiahMutt's Avatar
SkiahMutt
Aircon issues
Hello NAM! I'm having air conditioning issues.
System was possibly overcharged, but unsure(didn't get an accurate weight of the recovered refrigerant). Blew cold air from the passenger side vents, and warm air from the driver side. Also had significant whining from the compressor in stop and go traffic, but quiet at higher speeds(sounded like a second supercharger!)
System was drained and had a vacuum applied to it, held good vacuum, so I started recharging it. Got about 8 ounces of refrigerant in, and started noticing issues. The compressor was very noisy(whining mainly), the vents were still blowing quite hot air, and the high side pressure was getting very, very high(330PSI according to my gauge) while the low side pressure was staying below 35-40PSI. The electric fan kicked on, which dropped the high side pressure dramatically and quieted the compressor down, but shut back off after a moment which caused a pressure rise and lots of noise from the compressor.
The electric fan was recently replaced, and I believe low and high speeds are operating normally. Is the fan supposed to turn on with the compressor? If so, what triggers that and how can I diagnose it? Might I have a bad pressure switch?
After doing some further reading, I might have a defective fan resistor on the new fan. From what I'm reading, my high fan is cycling off and on, but my low fan isn't. I'm going to be quite irritated if that's the case.
Old Jun 30, 2022 | 06:16 PM
ssoliman's Avatar
ssoliman
Bad expansion valve. But that’s just a guess from an amateur
Old Jul 29, 2022 | 05:47 AM
khnitz's Avatar
khnitz
@SkiahMutt - just checking in - have you had a chance to get this resolved? Thanks!
Old Aug 25, 2022 | 04:39 AM
khnitz's Avatar
khnitz
@SkiahMutt - checking in again to see if you had the time to get this looked at and if a resolution was identified? Thanks!
Old Aug 25, 2022 | 04:28 PM
SkiahMutt's Avatar
SkiahMutt
Sorta? My low speed fan ended up being kaput(well, it was a wiring/fusebox issue), after fixing that I have A/C again, but my pressures are still too high and my compressor is still too noisy. Unfortunately I've been very unmotivated to work on the Mini lately, so I've just left it alone.
Old Aug 25, 2022 | 04:43 PM
khnitz's Avatar
khnitz
I'm leaning towards mine being a problem with the expansion valve. I've ordered that and a new receiver/drier and I'll give that a go.
techman1
Aug 28, 2019 09:24 AM
Mini33073
Jul 20, 2019 02:34 PM
Firefly1013
Sep 15, 2018 10:55 AM
end
Nov 12, 2012 09:47 AM
friday9x
Jul 27, 2009 03:51 PM
