R50/53 Did Ceratec blow my engine ?
Old Apr 12, 2022 | 10:40 AM
frankiev's Avatar
frankiev
I thought id post this in case anyone else is thinking of useing Ceratec oil additive Here's the story
I replaced the head, timing chain and guides on my 03 MCS . I started the car and let it idle fir 10 minutes , drained the oil and changed the filter. Then I put some Ceratec additive with fresh royal purple oil in and went for a road test .
The car ran great so I headed out . About 15min later the oil light came on but only at idle so I pulled over and checked the oil . It looked clean and was full so I thought I'd limp it hone since I was close . BIG mistake on my part as the engine siezed after about 2 blocks .
I realize it was my foolishness that was to blame , however I finally got around to draining the oil today and OMG it looks really odd , very thin .
There's no water as far as I can tell, no milky look ,and the coolant is still full so I'm wondering if the ceratec may have thined it out and caused the oil pressure loss .
I have no proof but if your thinking of using it I'd be very very careful .
Old Apr 14, 2022 | 01:37 PM
AcidK1's Avatar
AcidK1
There's that plunger I have read about in the filter housing may have been damaged?
I'm sure I read the handbook says do not use additives but I may be wrong :/
Old Apr 14, 2022 | 07:59 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
I used it every 25 k on my r50. Never had any issues.
I just replaced a bent rod due to an injector sticking. My rod bearings look brand new.
You must have had another issue causing your engine to lockup.
Old Apr 15, 2022 | 12:59 PM
Nervos's Avatar
Nervos
This
View this post on Instagram
Old Apr 16, 2022 | 11:00 AM
nd-photo.nl's Avatar
nd-photo.nl
Hmm strange indeed. I also used Ceratec for 2 years now without any issue (with a 5W30 oil).
CountryMouse
Dec 7, 2021 08:49 PM
speedmob
Feb 19, 2017 07:54 AM
kris kross
Nov 4, 2011 05:21 AM
Foxtrot_Xray
Feb 11, 2010 06:19 AM
tattman23
Sep 18, 2007 12:49 PM
