R50/53 Window doesn't move, motor sounds normal
Old Jan 11, 2022 | 07:27 PM
gonzo's Avatar
gonzo
I put my window down for a minute, then when I tried to put it back up it doesn't move. I can hear the motor running, there's no grinding or other odd sounds. I took the door card off and I can raise and lower the window by hand. I pulled it all the way up to see if I could lower the window with the motor but it does the same thing -- the motor runs but the window doesn't move.
I'm inclined to think it's the regulator but wanted to hit up the forum to see if there are any tips on what else might be bad and any tips on isolating the problem.
Thanks,
-g
Old Jan 12, 2022 | 02:52 AM
ChiefM's Avatar
ChiefM
Sounds like you snapped the cable on the regulator.
Old Jan 12, 2022 | 09:02 AM
cooper48's Avatar
cooper48
+1 on ChiefM. You should not be able to raise or lower the window by hand. Sounds like a new window regulator is definitely in your future. Word of warning: there are two plastic cable holders near the top of the door (inside) that hold the cables away from the moving window. Break those and you're in a world of hurt because they can no longer be purchased separately. They can be purchased as part of a window hardware kit but the kit will cost you around $40 and you won't need anything but the holders to replace the regulator.
Old Jan 12, 2022 | 10:09 AM
gonzo's Avatar
gonzo
Thanks for the info! I just ordered the regulator and it should be here tomorrow. Now if I can just go a few days without something else breaking on this car.. LOL.
exocet
Nov 19, 2013 10:40 AM
buggyeye401
Jul 2, 2012 06:14 PM
ridler
Sep 19, 2011 08:14 AM
04liquidS
Oct 23, 2010 09:20 AM
PortMCS
Electrical
Jun 27, 2007 06:15 PM
