R50/53 heat exchanger (oil cooler) replacement
Old Dec 5, 2021 | 08:17 PM
jgerry2002's Avatar
jgerry2002
My heat exchanger / oil cooler is continuing to leak slightly even after the o-rings were replaced twice on my 03 Cooper S.
Finally have a new oil cooler, which I now have after a bit of a wait from Mini.
Does anyone know how much coolant do you lose during this process if you just remove the two lines going in/out of the cooler?
I know the total system capacity is around 6L, but not sure if you lose a liter or two or most of it during this processes.
Old Dec 5, 2021 | 08:45 PM
BlwnAway's Avatar
BlwnAway
Considering where the feed lines are, probably 40% +/- .
Old Dec 6, 2021 | 12:52 PM
About a gallon is my guess. If you get the Genuine MINI stuff, just mix 50/50 with distilled water and you will have 2 gallons. One for extra jobs.
Old Dec 7, 2021 | 12:21 PM
wrxtance's Avatar
wrxtance
Having recently changed out the seals on my 06 Cooper S, I can imagine that fluid line clamps like these Harbor Freight clamps would work a treat. One on each hose and you should be able to limit the coolant lost to just what is in the exchanger itself. I have used these clamps for other (typically fuel related) jobs and they really help limit the mess.
Luckily for me, replacing just the seals fixed my oil leak
Scott Paist
Jan 3, 2017 07:36 PM
Noir2005
Mar 15, 2015 02:13 PM
th3band1t
Dec 8, 2012 10:59 AM
niquemarshall
Jan 29, 2012 07:07 PM
