R50/53 Am I doing this right? Reset brake pad sensor light
Old Oct 8, 2021 | 06:41 AM
miniattack's Avatar
miniattack
Hi,
I have tried searching for this but I am getting conflicting information. I got my 2004 mini S a couple months ago, and the brake light was on. The read pads were pretty low, so I changed them and at that time I cut the wires for the pad sensor and soldered them together. This will be a weekend car for me, so I will just check the pads regularly enough.
After that i searched online and on this forum for the correct light reset procedure. I found 3 different ways to do this:
1. put ignition in position 2 for 30 seconds
2. put ignition in position 1 for 15 seconds
3. use the button on the speedo to enter the menu and reset
I have tried all of these, and I am not getting it to reset. In case the front sensor was the one causing the issue, i cut those wires as well and soldered them.
I want to be sure that I am actually resetting this correctly before I start digging into wiring and connectors, etc. Can you please let me know what the correct procedure is?
Old Oct 8, 2021 | 07:57 AM
Grand-Cayman's Avatar
Grand-Cayman
Sorry for an obvious question, but is there a brake fluid sensor? Could that be it? I should know this because I have swapped out my brake master cylinder, but I can't recall, duh!
Old Oct 8, 2021 | 08:00 AM
miniattack's Avatar
miniattack
I am not sure if there is a fluid sensor, seems like there would be. The light on my speedometer is left of the airbag light. I was thinking this is the brake pad sensor light.
Old Oct 8, 2021 | 11:47 AM
mrbean's Avatar
mrbean
Sounds like the brake pad warning light. IIRC, ignition position 2 for 30 sec is the correct method but I've had trouble resetting it before. If the circuit has a little too much resistance the instrument cluster is hesitant to turn the light off. In the past, when replacing a worn sensor, the light refused to go off. I had to unplug the sensor and short the terminals with a paper clip.
Your solder job should accomplish the same thing. But it might be worth checking them just to be sure.
Old Oct 10, 2021 | 04:46 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
key on in power mode but don't start the car and let it sit 30seconds only and the light should automatically turn off , no need to do anything else . If it doesn't, it's not making a connection and you need to 2x check those finicky sensors.
Just take your sensor wires and splice them and wire them together( front and rear ) make sure you get a good chunk of wire exposed to do so as it often cracks fron heat above in the loom. So 2x check for that and splice it high as possible, I had the same issue with the light coming and going as the sensor never fit perfect in the new pads..and I don't need a light telling me pads are low , so I just spliced the wires together to make a complete circuit and keep that dumb thing off for good.
madmix
Wheels/Tires/Brakes
16
Sep 13, 2020 09:24 AM
focker
May 18, 2017 04:09 PM
Golfpunk2
R57 :: Cabrio Talk (2009+)
Apr 19, 2015 05:42 PM
jrprich
Jun 14, 2013 05:30 PM
actualsize
Tires, Wheels, & Brakes
Nov 1, 2006 06:53 PM
