R50/53 Transmission issues
Old Sep 2, 2021 | 09:09 AM
Brandon Fluharty's Avatar
Brandon Fluharty
Transmission issues
I just rebuild my motor and I replaced my axles and when I went to try to put it in gear it won’t go in but it’ll still move a little like it’s halfway in and it’ll go into reverse but it crunches it’s way in and shakes the car and idk what I did wrong it has a new clutch new pressure plate remained flywheel and new redline transmission fluid with new shifter cables
Old Sep 2, 2021 | 09:16 AM
Brandon Fluharty
it does let me shift into gear with the engine off and if I turn it on it’ll move in gear but if I take it out of gear I can’t put it back in
Old Sep 2, 2021 | 09:19 AM
Corkus's Avatar
Corkus
Sounds pretty much like my bad Clutch Slave Cylinder. If it is, then that's not so bad. $30 for the exact same-as-OEM-part from Pelican or Out Motoring. my first time bleed went well.
Old Sep 2, 2021 | 09:26 AM
Brandon Fluharty
I would love for it to be that but I just put a new one on because when I took the old one off it exploded I just bled the new one but it’s still a tad spongy would that be it?
Old Sep 2, 2021 | 09:30 AM
Corkus's Avatar
Corkus
Maybe a bad bleed? My clutch pedal went from spongy to feeling perfect the moment it was fully bled. I could not bleed this thing properly until I bench bled the part off the car as described in the link about my first bleed.
Your situation caught my eye because I had the same symptoms:
-shifting works with the car off
-won't go into any gear with the engine running
But what do I know? I have only bled one thing once. Lots of others know more than me.
Old Sep 2, 2021 | 09:40 AM
Brandon Fluharty
by bench bleeding did he mean setting the slave cylinder up with that jig like in mod minis videos because I’ve already bleed it like that but I can’t seem to get a stream of fluid to come out like his videos it’s more of a line of drops
Old Sep 2, 2021 | 09:44 AM
Corkus's Avatar
Corkus
I feel silly quoting myself because there's an excellent chance Brandon knows a helluva lot more than me but here goes:
By Pre-Bleed (more properly Bench Bleeding) I mean with the Slave Cylinder removed from the car and compressed by the tool I slowly filled it with fluid and worked the bubbles out of the unit by pushing on the plunger with my thumb and other times by tapping the plunger with a wrench. Sometimes I could hold the unit vertically during the process which of course you can't do when it is on the car. I could only add a few cc's of fluid at a time and then I worked that into the unit mostly by pushing and tapping on the plunger while it was compressed already. There was enough play left in the plunger that I could move it slightly and in this way I was able to fill it up with no bubbles inside - I think. Then with as much fluid as it could hold I carefully carried it over to the car and installed it without spilling any fluid from the unit. Seemed to work very well. Maybe Pre-bleeding this Clutch Slave Cylinder is a good thing.
Here is the link to my full description.
Old Sep 2, 2021 | 09:51 AM
Brandon Fluharty
oh ok that makes sense I’ll give it a try after work today and hopefully it was just a bad bleed job like you suggested I’ve never had the best luck bleeding this thing I can rebuild the motor but I can’t led the clutch lol
Old Sep 3, 2021 | 06:59 PM
Brandon Fluharty
update on the bleeding process ive spent the entire day bleeding this stupid thing even hooked up a bottle to tell if air is coming out or not and there isn't but when i bolt up the slave cylinder the pedal still hits the floor i have spent all day getting the air out of the system and the only thing i can think of is that the master cylinder and or slave broke during the process. im out of ideas and i don't reaslly want to replace the master if i don't have to
Davicho
Sep 11, 2021 03:30 PM
That_Guy
Sep 27, 2017 10:04 PM
ericscottf
Jun 27, 2016 09:47 PM
Montana Miniac
Jun 26, 2012 03:47 PM
Justjones
Mar 29, 2010 04:53 AM
