R50/53 My Impressions of a modded 03 MCS vs my stock 05
Old Jan 12, 2005 | 09:28 AM
  #51
minibrute's Avatar
minibrute
old new vs. 05
Bring the modded 05's on, will travel within 100 miles from L.I. N.Y. for some speedplay.
Old Jan 12, 2005 | 09:40 AM
  #52
C4's Avatar
C4
Originally Posted by JCampos
Yes, no doubt the '05s have the initial power, but that isnt magic power.... the '04s will still overtake it at higher speeds.
You mean stock '04 vs stock 05?
Old Jan 12, 2005 | 12:12 PM
  #53
DR61's Avatar
DR61
For the record, MINI lists the top speed of the 2005 MCS as 134 MPH, while the 2004 is listed at 135 MPH. The gearing and additional power of the 2005 should allow it to attain 134 before the 2004 does, however the 2004 should gradually overtake the 2005 given a long enough, flat straight. In almost any situation on normal roads, and on almost all road race tracks, the 2005 should give faster lap times (all else being equal). The 2004 should give greater fuel economy, however.
Old Jan 12, 2005 | 12:44 PM
  #54
C4's Avatar
C4
I taught the max speed rating of the '05 MCS was 138 MPH vs 135 MPH for the '04 model.
Old Jan 12, 2005 | 01:32 PM
  #55
TheOfficeMaven's Avatar
TheOfficeMaven
Yes, it is... The lower gearing and the additional torque/HP allow the newer cars to achieve a greater top speed than the older cars (in stock form).
Old Jan 12, 2005 | 01:34 PM
  #56
DR61's Avatar
DR61
I just saw the 134 MPH figure on the MINIUSA.COM site (specs for MCS). Is it different on non-US models?
Old Jan 12, 2005 | 07:02 PM
  #57
indygomini's Avatar
indygomini
where to put the $ ?
Originally Posted by andy@ross-tech.com
I'd expect more than 10 lb-ft from a 15% pulley. On my car, it was almost 15 lb-ft at the wheels. An '05 with pulley, intake, chip, cat-back should be able to easily dispatch a similarly modded '02-'04.
I thought the 19% would be enough to stay among the quickest, but maybe not. Looks like us early-year folk will have to escalate to keep up with the new arrivals once they start "evolving..."
Originally Posted by minibrute
Interesting stuff, it won't be long before we start to retrofit 05 gearing to our 02-04's. I envision 05 mcs trannys on e bay already.
Although secondhand and salvage powertrain components are starting to show up on the market, they are still very pricey. For an '05 gearbox with LSD, it'd probably be easier to order one through a dealer that offers NAM users a discount.
Anyone comtemplating going to the trouble of a gearbox retrofit is approaching the price point where twincharging or an Autorotor supercharger conversion starts looking like a compelling alternative. Once one of those is fitted, I'd expect the revised gearing is moot, since, as has already been stated in this thread, there's no point in having any more torque than the tires can cleanly put to the pavement.
To me, the money seems like it'd be better invested in the engine rather than the gearset. Unless, of course, you care about at least trying to keep a small portion of the remainder of your powertrain warranty intact.
Show me that Getrag AWD conversion as a production kit, though, and then I might see sufficient reason to swap out the transaxle!
Old Jan 12, 2005 | 09:14 PM
  #58
MyPocketRocket's Avatar
MyPocketRocket
I have 04 MCS March built. I did test drive 05 MCS and I don't feel much different at all. Yes, I did floor every gears from 1-3 in front off the dealer...but that doesn't give me much feeling over 04.
On the same day my buddies let me took their 04 NISSAN Z and 04 VW Golf Gti....now these car you can really feel the kick! Gti is much more punch than MCS no matter 04 or 05, but the gearing is real short. I have to manage to shift like a maniac. Nissan Z is totally monster!! 3rd gear up the hill and the car just pull like rocket....still love my MINI thou!
Now I have 15%, CAI and Exhaust...plus tall 1st gear the car just...totally rocks!
Old Jan 13, 2005 | 01:43 AM
  #59
allan's Avatar
allan
True ... you cant redline in 6th...
my '05 with a CAI, ss kit, springs,and 17% pulley--simply flies! and i mean flies!
allan
ps i test drove '04's and the thing i didnt like before i even knew whether was a gearing change coming-- was the gearing. Big difference.
BTW... i did a review of my car (motoringfile.com) before and after putting in the pulley on my '05.
http://www.motoringfile.com/2004/10/...iewed#comments
Old Apr 19, 2005 | 11:34 AM
  #60
andy@ross-tech.com's Avatar
andy@ross-tech.com
Originally Posted by LombardStreet
My understanding is they're lower across the board. I don't recall where I picked this up, but I've got this on my hard drive:
2005 MINI Cooper S trans ratios:
1st 12.789
2nd 7.793
3rd 5.651
4th 4.615
5th 3.828
6th 3.126
2004 (and earlier?):
1st 11.425
2nd 7.181
3rd 5.397
4th 4.407
5th 3.656
6th 2.986
Using 100*(2004-2005)/2004 I came up with the following percentages:
1st -11.9%
2nd -8.5%
3rd -4.7%
4th -4.7%
5th -4.7%
6th -4.7%
Watch out, all you '05 MCS owners. Since installing 205/40-16 Falken Azenis RT-615's, my gearing is now:
1: 3.5% taller than yours
2: Same as yours
3: 3% lower than yours
4: 3% lower than yours
5: 3% lower than yours
6: 3% lower than yours
Old Apr 19, 2005 | 12:09 PM
  #61
GBMINI's Avatar
GBMINI
Neat trick
What does that do to your speedometer? (if you care what speed you are doing!)
Old Apr 19, 2005 | 12:14 PM
  #62
andy@ross-tech.com
I compared the indicated speed on the speedometer against the measured speed from GPS and it looks to be a consistent 11% difference. So, in order to go an actual 70 mph, I should put the speedometer at an indicated 77.7 mph. Simple enough for me.
Old Apr 19, 2005 | 07:23 PM
  #63
Zociac's Avatar
Zociac
Andy,
Not so fast! Your numbers are true only if we 05 owners stick with the stock size.
In my case I dumped the RF and went with Azenis Sport in 215/45-16. Running the numbers:
1: 0.1% lower than yours
2: 3.4% lower than yours
3: 0.4% lower than yours
4: 0.4% lower than yours
5: 0.4% lower than yours
6: 0.4% lower than yours
Better yet my tire width is 4.9% wider than yours.
2: Same as yours
Old Apr 19, 2005 | 08:41 PM
  #64
tradiuz's Avatar
tradiuz
MTH Specialist
I'm kinda shocked noone's shown the '02-'04 MC vs the '05 MC (midland vs getrag!).
Old Apr 19, 2005 | 09:30 PM
  #65
1nf3rn0's Avatar
1nf3rn0
as to the top speads you were refering to, they are based on computer speed limiting. With enough power, a mini redlined in 6th could hypothetically break 150...
Old Apr 19, 2005 | 09:48 PM
  #66
JCampos's Avatar
JCampos
Originally Posted by Zociac
Andy,
Who cares about gearing... here is my breakdown....
1: Faster than yours
2: Faster than yours
3: Faster than yours
4: Faster than yours
5: Faster than yours
6: Faster than yours
I must say, initial torque on the '05s is much different... but it still seemed to bog down at the same spots as the stock '04s do. I really dont think this gain is much other than getting you off the line faster.
sevin
May 2, 2026 06:11 AM
Kimolaoha
Dec 5, 2020 09:32 PM
minipopkart
Aug 13, 2015 05:22 AM
massmini03
Aug 12, 2015 11:19 AM
