R50/53 Removing warning sticker
Old Dec 6, 2002 | 12:06 PM
mikegre's Avatar
mikegre
Just got my new Mini S. There's a warning sticker on the front of the glove box...air bag danger, etc. Has anyone tried to remove it? I'm asking because sometimes these things are not meant to be removed, and if you try, it leaves a big ugly mess behind.
Old Dec 6, 2002 | 12:08 PM
Motorthis's Avatar
Motorthis
My dealer removed mine when they detailed it. Get some goo be gone.
Old Dec 6, 2002 | 12:18 PM
orbhot's Avatar
orbhot
I used a few drops of lighter fluid and an old sock, the stuff is great for removing sticky crap and doesn't damage most surfaces. Just don't smoke while cleaning
Old Dec 6, 2002 | 12:31 PM
2minis's Avatar
2minis
Storer's Avatar
Storer
I had a priest exorcize that beast from my MINI... no wait, I pulled it off and it didn't leave any residue
Old Dec 6, 2002 | 12:32 PM
Storer's Avatar
Storer
Old Dec 6, 2002 | 12:35 PM
2minis's Avatar
2minis
Actually, what I advise is opening the passenger window
and having a friend grab the sticker and pulling away slowly.
Tell your friend to stand in place and the sticker should
come off.
Old Dec 6, 2002 | 12:39 PM
Daron's Avatar
Daron
Not knowing what various cleaners and flammable liquids would do to that panel, I opted to play it safe and use liquid car wax to clean up the gooey residue left from the warning sticker. The wax worked great.
Old Dec 7, 2002 | 08:57 PM
gobsmaked's Avatar
gobsmaked
DON"T DO IT! They sticker police will come after you and destroy your life! I can't tell you who I am, they made me put the sticker back, even though I didn't know her I didn't mind that much, but they can delete your life with the stroke of one button.
Oh, orbhot, whats up with the sticky stuff and an old sock?
Old Dec 8, 2002 | 06:55 AM
camwhit's Avatar
camwhit
Citrus bike cleaner works great to remove the sticky residue and it doesn't harm the finish, plus it smells very citrusie when you're done!
Old Dec 8, 2002 | 01:32 PM
LikeABrave's Avatar
LikeABrave
Peeled it off really slooooooooowly. Not a smudge.
Old Dec 8, 2002 | 01:50 PM
Pamlico's Avatar
Pamlico
A constantly recurring thread.............As mentioned above, peel it off very slowly. If any residual remains, press the back of the just removed sticker onto the residual and pull off. You may need to repeat a few times, but this should remove all the remaining sticky without the use of any chemicals.
Old Dec 8, 2002 | 07:15 PM
TBP38's Avatar
TBP38
heat a little with hair dryer, use a tooth pick or saftey razor to lift most of it off, then use some GOO GONE to remove adhesive
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
cawwwtun
May 3, 2016 08:03 AM
Mrdi
Aug 29, 2015 03:18 PM
greekzilla
Aug 23, 2015 03:44 PM
JamJam43087
Aug 16, 2015 02:02 PM
