R50/53 No communication with ECU
Old May 27, 2021 | 09:39 AM
chip05's Avatar
chip05
I have a 2005 Non S My check engine light came on and I can't scan it for codes tried 3 different scanners that worked on it previously they will power up but no communication, fuses good any help would be appreciated.
Old May 30, 2021 | 06:11 AM
ramjet77's Avatar
ramjet77
There's a mechanic on YouTube that worked on a Mini with just the same problem. He pulled out the OBD connector and checked the female terminals and some showed they were too loose to make a connection with the scanner. He used a pick (you can use a small screwdriver) to rebend the female connector and that solved the problem.
Old May 30, 2021 | 06:19 AM
ramjet77's Avatar
ramjet77
I was mistaken about the car being a Mini, but here is the link to the possible fix. Sorry, I couldn't get it to hyperlink
Oops, I guess it did.
Old May 31, 2021 | 10:02 AM
nd-photo.nl's Avatar
nd-photo.nl
I had a similar issue on a VAG car with aftermarket radio. After disconnecting it, it worked.
aowolf
Sep 12, 2020 08:50 PM
Finhead
Electrical
Apr 12, 2019 04:05 PM
OCR
Aug 26, 2018 08:44 AM
johntotah94
Jul 11, 2018 08:20 PM
SpiderX
Mar 6, 2005 02:45 PM
