R50/53 Best brake setup for stock size calipers/ rotors
Old Dec 15, 2020 | 09:41 AM
  #26
930 Engineering's Avatar
930 Engineering
First of all, I do like the looks of Holies wrapped with meaty 195/65 R15 tires. I've never driven a Mini with 15" wheels, but I'm sure it will ride nice. Doesn't it rub on bigger imperfections?
Originally Posted by OCR
Friction creates the stopping power...right ?
With all of the cool holes and slots in your rotors, that's a bunch of material that...does not...create friction anymore..!
At one point many years back, the way the pads were made, they created and expelled gasses from the heat. The holes and grooves helped keep the pads against the rotors. That's...not...a requirement any longer. Pads are manufacturers much better nowadays, and don't outgas like they used to.
While I agree with you on holes and grooves being useless on a daily driver I disagree on resulting friction. Contrary to popular believe surface area does not contribute to friction as long as we talk aboth smooth and hard surfaces like brake rotors and pads (soft tires are a different story). It's both coefficient of friction and pressure only (according to Coulomb). Surface area however does play an important role when it comes to heat transfer and distribution. So when you stress your brakes more brake pad area will help transfering heat to the rotors and thus to the surrounding air.
Originally Posted by Benjamin Tatham
I have and would like to keep the R81 wheels on my R53. Even on the stock breaks, the clearance is tiiiiiight!
So, I want to improve the stock setup as much as possible while not doing things like changing to a larger caliper/ rotor. What do you recommend to get the most stopping power for the littlest investment on the stock setup?
It's easy. Just get new pads. Even stock ones will most probably gain a noticeable advantage as they're new and not old. I'd go for reputable brand stuff like OE Mini, Ate, Brembo, PFC, Ferodo or Pagid. Avoid EBC.
While swapping pads make sure you thoroughly clean the sliding/contact areas of your calipers. Since BMW/Mini calipers use to be zink/electroplated avoid using a steel brush. Use a nylon brush if possible and some appropriate ceramic high-temp grease.
Originally Posted by njaremka
Best thing you can do to improve brake performance is better pads and stickier tires. If you can lock up the wheels as is, or activate ABS, your tires are the limiters. If you can't lock up the brakes, your pads need upgrading.
Agree!
Originally Posted by RB-MINI
Besides all that was mentioned above, stock R56 - R5(X) non-S calipers might be an option if they’ll clear your wheels. They have larger pads than the R53 for more friction, but use a rotor that's almost the same diameter, 276mm vs 280mm if the info on the 'net is correct.
Although the R56 S and non-S calipers are the same, the carrier/mounting bracket is different for the different sized rotors. The brackets can be changed, but this usually adds significantly to the cost and can be hard to find separately so getting the correct assemblies the first time is best.
That’s what’s bad with a lot of the poor man’s JCW upgrade and question threads. “R56 calipers” is often used loosely and don’t stress only S caliper assemblies will fit the 294mm rotors.
Even though Benjamin stated not to invest in new calipers and rotors this is a great idea. R56 Justa brakes are proven to fit under Holies and due to the more advanced and stiffer design of the bigger TRW calipers and 54 mm instead of 48 mm pistons they provide more bite and less hysteresis. However for surface area see what I said above.
Let me add that R56 Justas and MCSs do NOT run the same pads. Dedicated S pads have a slightly different shape and bigger surface area.
are you certain the calipers are the same size as stock? I am on the 15” r81 wheels and there is zero additional room under there.
Well, while there's not that much of space, there is actually 'some' space left, since Holies do fit R56 Justa with TRW15 calipers and 280 mm rotors.
Originally Posted by MrBlah
are those even worth the time swapping on?
Since TRW15 calipers are a more advanced design, stiffer and bigger, carry 54 mm instead of 48 mm pistons they do provide more than you'd expect from just going a few mm bigger rotors.
More bite and less hysteresis result in better feel. That doesn't necessarily mean shorter stopping distances though.
Originally Posted by IQRaceworks
It's simple physics....nothing more, nothing less.
Less rotor to pad contact (because you have holes and slots) = less friction. Less friction = longer stopping distance.
Do a Google search for 'Coulomb friction' and have a read.
Old Dec 15, 2020 | 10:55 AM
  #27
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
that is a significant piston area change increasing front bias ! I like to stay near stock bias or the rear likes to tail wag too much
Old Dec 15, 2020 | 12:04 PM
  #28
Racingguy04's Avatar
Racingguy04
wouldn't increasing the braking force up front decrease the chances of the rears locking up first? I can't say I have tons of experience adjusting brake bias, so I might be misunderstanding it.
Old Dec 15, 2020 | 12:48 PM
  #29
MrBlah's Avatar
MrBlah
stock bias has the fronts lockup before the rear, using a bigger piston area up front will make this issue even worse. On track in heaving braking there is a lot of tail wag due to lack of braking in the rear. It's hard to get this under control as rear pad temp is basically cold compared to the front.
I dialed it out by using a higher torque pad in the rear and slowing down my rear coilover rebound speed. With single adjustable coilovers this would be harder to deal with
Old Dec 15, 2020 | 01:41 PM
  #30
Racingguy04
Ah, so you're not locking up the rears, but rather since they're not getting braked at the same rate as the fronts; the back end is trying to roll around the front?
Old Dec 15, 2020 | 02:02 PM
  #31
Benjamin Tatham's Avatar
Benjamin Tatham
Originally Posted by AngryScotsman
I hope anyone who reads your post, also reads your post history, and then ignores it.
Some notes before tackling the "best brake setup" (all of this has been covered before):
- Brakes actually don't "stop" the car. Tires do. Brakes just speed up the process. It's why having the "greatest" brakes in the world on a icy road means almost nothing.
- Brake fade is when there's too much heat in the system (fluid, rotors, pads, calipers, etc). Getting rid of this heat as quick as possible or preventing it is ultimately the goal of larger rotors and brake ducts.
- Stopping distances and times change. You doing a panic stop at 70mph on a freeway is different than someone doing 70-0mph stops 10 times. Race pads generally take longer and further to stop a car during panic stops than the repetitive stops you'd see on a road course.
- Larger rotors don't equate to shorter stopping panic stops. They equate to better fade resistance, which means they can handle repetitive stops better.
- People who say they had better brakes after replacing their worn out components with x-drilled rotors are confused. I could replace a set of 5 year old Toyo RRs with some Walmart brand tires and have better grip -- that doesn't mean the Walmart tires are better.
- Stainless braided brake lines are good for brake pedal feel, they do nothing else. For street cars, run rubber lines -- They are easier to inspect for wear and damage over the braided lines that can hide damage/worn the rubber lines underneath.
- The easiest way to test your brake system is: Slam on the brakes. If your tires lock up and you're sliding, you need better tires. If you can't (ignoring ABS involvement), your brakes need attention.
So, with that all said (and there's a ton more to dig thru), the best braking setup is:
- The best tires you can afford and safety drive in your area. It's winter for many and driving around on some fresh A7s would be insanely unsafe.
- Properly bedded brake pads. Depending on your driving style, you can use a more performance oriented pad or autozone specials. Performance pad if you do spirited driving and want the better fade resistance at the sacrifice of marginally worse panic stop performance -- or autozone specials which will have the inverse.
- Solid, vented, two piece rotors. The two-piece and vented design will help with fade resistance and the solid rotor will help with the panic stops.
- Fresh and properly bled brake fluid.
- Good condition brake lines.
Good luck
appreciate the thorough reply. My goals are: low dust, goodish cold bite (lots of short trips), good pedal feel, long lasting, needs minimal maintaining.
so, solid rotors, ceramic pads? (Have on my truck- haven’t noticed any issues with cold stops), maybe new rubber lines? I was thinking stainless braided, but your post is making me think with regard to visual inspection.
Old Dec 15, 2020 | 02:09 PM
  #32
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Benjamin, as others have so aptly put, and I will concur, the least expensive thing you can do to increase your braking is to take off the "bling" rotors and sell them to someone who wants to look good more than stop well. Replace them with a pair of good, cheap, solid rotors like CENTRIC. Bed them in properly using good set of better compound pads...not race compound, though. The higher priced compounds are great for the track or carving the twisties but they have to be in their "sweet spot" temp-wise before they perform well. Cold, they can scare the snot out of you! Stainless lines won't help you stop much better but will help you feel the pedal, thereby allowing you to modulate your braking better.
Old Dec 15, 2020 | 05:55 PM
  #33
MrBlah's Avatar
MrBlah
i wouldn't say it's trying to come around, more like it makes the rear want to wag its tail a bit, easily correctable but unnerving because it's high speed heavy braking
Old Dec 15, 2020 | 07:16 PM
  #34
shrevemini's Avatar
shrevemini
Top Answer: 1
Did my brakes on my r50 a couple weeks ago.
Old Dec 15, 2020 | 09:13 PM
  #35
930 Engineering
You are right. That's why factory cars are designed that way or have been before they had anti-lock systems.
Wheels that are braked less hard will show less tendency to lock and remain more stable. Basically that's not a bad thing.
It isn't an issue at all. You may remember about 15 years ago Mini sold the old JCW brake kit with the same (later R56 style) TRW16 calipers and 294 mm rotors. It's been a clear progression over the stock R53 brakes. Don't you think if your concerns where true that kit would have made things even worse than running the R56 calipers along with 280 mm rotors?
However I do understand concerns about altering brake bias in general. Better to know what you're doing, but in this case it's a non-issue. R50/53 Minis come with electronic brake distribution. When sensing lock-ups it will readjust brake bias (within system limits).
Track is an entirely different task. I think we're not talking about track here. Driving on public roads means safety first, not things like rotation . . .
Feel free to retrofit 280 mm rotors on rear along with the corresponding carriers (R56 JCW & GP setup). The calipers are the same for both 259 and 280 mm (at least this applies to R56 Minis). I plan on doing this.
While I agree on slotted and/or drilled rotors being more 'bling' than functional I wouldn't go so far saying they brake worse and he should replace them asap. If there's still some life in them left I'd keep them and just replace the pads. Cracking is not particularly likely to be an issue on street driven cars. That's mainly a track thing.
Old Dec 16, 2020 | 04:59 AM
  #36
IQRaceworks's Avatar
IQRaceworks
...as far as cracking goes.... I've used those cheap drilled and slotted rotors on everything from a Dodge Ram 1500, a Ford F350, my 335i, and my R53 ......all of them got small cracks coming from where the holes were drilled after a year or less. Not to say that any of them actually came apart, but they did crack. They are cheap for a reason......those "kits" come with cheap rotors, and cheap ceramic pads. A good set of OEM quality pads and OEM style solid rotors has a noticeable improvement in braking over those cheap ebay drilled and slotted rotor kits with the cheap ceramic pads.
But....back when I was young, dumb, and didn't know any better.....that's what I thought would make my vehicles stop better. I was wrong.
Old Dec 16, 2020 | 06:28 AM
  #37
MrBlah's Avatar
MrBlah
sure was a issue on both my cars, I upgraded the rear to R56 trailing arms and calipers, better sweep & pad area and it helped quite a bit, along with a higher torque rear pad
For street use it's probably fine, but I autocross, hpde, time trial and it's a significant issue there
Old Dec 16, 2020 | 08:46 AM
  #38
930 Engineering
How often do you think Benjamin does visit a track or autocross? He's currently on 195/65 CrossClimates btw.. Not what I'd call a track-oriented setup.
For proper advice it's most helpful catering for the OP's needs and suppress one's own necessities. Honestly, no offence intended.
Old Dec 16, 2020 | 09:16 AM
  #39
MrBlah's Avatar
MrBlah
none taken I was answering a question by another poster
Old Dec 16, 2020 | 10:33 AM
  #40
Minibeagle's Avatar
Minibeagle
These brake pad / disk recommendation threads are always a hoot to read.
It's always a balancing act between what looks nice and what is the intended use of the brake system (daily driving / commuting vs. occasional autox / light lapping vs. serious autox / heavy lapping). As some have already stated, many of us have come up with solutions that wok for us but we have to remember that we don't all use our MINIs in the same way.
Old Dec 16, 2020 | 02:49 PM
  #41
Benjamin Tatham
haha- I do have a second set of wheels and would like to do an autocross day, but my needs could be described as rally grocery getting. I want the best performance a stock set up can offer- i like to go fast, but I definitely don’t test the limits too often
Old Dec 16, 2020 | 02:53 PM
  #42
Benjamin Tatham
[QUOTE=930 Engineering;4566204].
surprisingly, I have gotten no rubbing at all. Have hit some decent bumps and drive over speed bumps and tail road tracks constantly where I am. 195/65/15 are definitely a fit.
Old Dec 16, 2020 | 03:15 PM
  #43
MrBlah's Avatar
MrBlah
Well the best stock is pretty easy you want to find the r56 s front and rear and get the trailing arms to go with it
Old Dec 17, 2020 | 10:30 AM
  #44
SupeR53's Avatar
SupeR53
15" Wheels won't clear the R56 calipers in front.My daughter just went through this when her '08 Justa got totaled and she bought an '07 MCS, the 15" wheels just won't clear the R56 calipers.
Old Dec 17, 2020 | 10:49 AM
  #45
MrBlah's Avatar
MrBlah
Most wont but some do, I run 15x8 or 15x9 949racing wheels with a 10mm spacer and r56 fronts or wilwood fronts and they clear both
Old Dec 17, 2020 | 10:59 AM
  #46
SupeR53's Avatar
SupeR53
Let me rephrase that... The stock Justa 15" wheels didn't clear the R56 calipers.
Old Dec 17, 2020 | 11:13 PM
  #47
MiniManAdam's Avatar
MiniManAdam
Community Builder
Good luck
Lol ok..so my buddy who tracks his r56 every year and has personally did stock vs drilled n slotted ect experimenting which was best setup.. for hard short braking , you need absolutely as much cooling as possible..this isn't the 70s and tech has changed , even how they now add the hole and slots to the rotors has changed so they don't crack like they used to..I won't argue anymore with some of ur guys nonsense . Just like trying to say stock intercoolers are the 2nd best you can have lololol i personally debunked that with just a cheap ebay bigger one. Showed other members my results and they've bought them too and are loving them. O yea, my cheap injector upgrade too others tried calling me out for.. id LOVE to race some of you know it alls in my mini and just EAT YOURS ALIVE with mine.. and then I sit here too and laugh at all the issues your cars are having but yet yours are put together sooooooooo much better ..hahaha ya, go read my posts fool.
Old Dec 17, 2020 | 11:14 PM
  #48
MiniManAdam
Community Builder
Originally Posted by minibeagle
these brake pad / disk recommendation threads are always a hoot to read.
It's always a balancing act between what looks nice and what is the intended use of the brake system (daily driving / commuting vs. Occasional autox / light lapping vs. Serious autox / heavy lapping). As some have already stated, many of us have come up with solutions that wok for us but we have to remember that we don't all use our minis in the same way.
exactly !!!!!!
Old Dec 18, 2020 | 06:39 AM
  #49
IQRaceworks
Sorry....but I'm not listening to any type of technical information from a guy who covers up the intake ports on his supercharger with JB Weld to "increase flow and make it louder"...........you lost all credibility with that nonsense.
Not to mention you can't even change a belt tensioner without screwing it up......
Old Dec 18, 2020 | 06:43 AM
  #50
MrBlah's Avatar
MrBlah
I do the same thing, eaton engineers said it increases efficiency basically slightly less heat generation. Non OEM eatons typically do not have the silencer ports, they do not have to manage the noise
