R50/53 Backward question R53 to R50
Old Nov 9, 2020 | 08:36 AM
JohnMcF's Avatar
JohnMcF
OK, weird question. I'm into SCCA club racing. Have the opportunity to get an S model chassis that will be parted out by a friend of mine. Now the class I want to run will require a base model setup for the engine. My question is in regards to the engine management system/harness and ECU. Being an S model I know the wiring is set up for the forced induction. I can swap in a R50 intake simple enough. Would I need to swap out the entire wiring system?
Comments?
Old Nov 10, 2020 | 07:31 AM
JohnMcF's Avatar
JohnMcF
So is it that stupid of a question I get crickets?
Old Nov 10, 2020 | 08:13 AM
wmcoons's Avatar
wmcoons
Are you trying to run a supercharged engine as N/A? Or are you swapping an N/A engine into the car?
The supercharged engine has a lower compression ratio so if you run it as N/A it may be down on power and not run right.
If you swap in an entire N/A engine, wiring harness, and ECU I think that would be your best bet.
I have an R53 and haven't worked with any N/A stuff so just my best guess.
Old Nov 12, 2020 | 01:33 PM
JohnMcF's Avatar
JohnMcF
I just have an opportunity for an R53, but in SCCA I would have to run it totally restricted as an S in STU or could run H Production if I can get it to run base specs. The motor issue is the easy part. The real question was could you use the R53 wiring to run a base setup or would the engine harness and ECU need to be completely swapped.
TheClassyMonk
Jun 10, 2016 07:18 AM
got_mini?
Nov 16, 2015 07:46 PM
soccerbummer1104
Electrical
Jul 1, 2014 03:37 PM
kellini
14
May 9, 2011 06:41 PM
Cudda_Kine
Cooper (non S)
Aug 5, 2008 12:44 AM
