03 MCS - Thermostat / Radiator Cap question - HELP!!
Old Sep 11, 2020 | 03:55 PM
SydeShowJoe's Avatar
SydeShowJoe
Hi,
unsure if this is the place to post this question:
looking into buying an 03 MCS with 140k miles. Price is set to sell fast (1400). Known issue per OBD scan is the O2 sensor needs replacing. However, after running the car, coolants started to leak from the radiator cap. Does this automatically mean stuck thermostat? Or could it be bad radiator cap?? Car has sat for months (~6). If I buy it, I’ll have to drive it 2.5 hours. The car did not run hot during the initial drive. Temp gauge stayed rig where it’s supposed to be. Need help - is this a potential sign of a lot of major repairs or just a quick replace of the radiator cap?
thanks!
Joe
Old Sep 11, 2020 | 05:06 PM
OCR's Avatar
OCR
Judging from my car (05), I'd say three things.
1. Bad cap.
2. The cap needs to be "tight". Tighter than you'd think on a plastic reservoir.
3. Water level too high.
Buy a new cap, install it tight, and let the water level find it's own height.
On mine, the..."no seep", level is just above the plastic bottles seam (top to bottom). That's where mine stops pushing water past the cap. Mine runs just below the mid mark on the gauge as a "running" point.
Mike
maddog2020
Aug 25, 2019 12:19 PM
Cabalabadingdong
Apr 18, 2012 04:49 PM
Louispup
Feb 3, 2011 12:46 PM
classicfreq
Classic Mini Talk
Oct 28, 2006 03:06 PM
The MINITOR
Nov 28, 2005 03:03 PM
