R50/53 ANYONE TRIED THESE ? Oil pressure sender adapter
Old Jul 14, 2020 | 06:53 PM
Serafin's Avatar
Serafin
Anyone tried these? https://www.ebay.com/itm/MINI-Cooper...-/301814251351
just looking for options.
also will the water temp sensor fit on the overflow plug?
Or i have to get these?
Upgr8 Aluminum Water Temperature Sensor Adapter (32MM, Red) https://www.amazon.com/dp/B00FY2WEC6/ref=cm_sw_r_cp_api_i_LfMdFbE13X5FT
thank you
Old Jul 14, 2020 | 07:12 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
I have it on my 04 r50 for added oil pressure sensor. Worked great for me.
Old Jul 14, 2020 | 08:59 PM
Serafin's Avatar
Serafin
Thank You. Ok ordering it. Did you have to use Teflon tape? Any other tips? What about the water temp?
Old Jul 14, 2020 | 09:02 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
I used liquid thread seal from autozone. I have installed chrono in my 04. So it has temp gauge. I also have a scangauge ii to monitor water temp.
Old Jul 14, 2020 | 09:07 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Do you have a R50 or R53. If you have a R50 it very difficult to add water temp inline . Do to radiator hose location. It is easy on a R53. Hose is exposed on the top front of charge air cooler . That's why I run a scan gauge on mine. I just upgrade from big center speedo to chrono. So now I have water temp on dash.
Old Jul 15, 2020 | 05:15 AM
Serafin's Avatar
Serafin
i have an 06 r53 I’m building. About to add boost water temp and oil pressure.
heard about putting h tu e sender in the head?
there’s a threaded plug already.
Thank You so much.
Old Jul 15, 2020 | 05:40 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
Not that I know of.
Old Jul 22, 2020 | 10:44 PM
Tragesaurusrex's Avatar
Tragesaurusrex
Personally I’d avoid tapping your own send location if you can help it. The craven adapter is a pricy little thing, but worth it IMO.
Im running one for my autometer send unit. Adding a brass 45 elbow from the adapter to the send unit helps fitment a ton.
If you have the room and want a lil extra security, you can use a fuel pump mount to mount the send unit remotely. This will insulate it from vibration and it won’t bend or break if you knock it around while working on the car.
Here’s my pseudo write up:
https://www.northamericanmotoring.co...ml#post4536893
Good luck with the gauges
Old Jul 23, 2020 | 06:34 AM
Serafin's Avatar
Serafin
thanks. And great write up. But isn’t this the same thing but better? I won’t be tapping anything
Old Jul 23, 2020 | 08:18 AM
Tragesaurusrex
Oh yes, it's the same thing. I misread post #6. Thought you were contemplating an alternate location for the oil press send unit. Don't mind me
Old Jul 23, 2020 | 11:56 AM
Serafin's Avatar
Serafin
great idea on the mounts. You have part number for that?
any suggestions on Where to the water temp Sender? Top radiator hose or the block?
Old Jul 23, 2020 | 12:44 PM
Tragesaurusrex
Here's the fuel pump mount I used:
Amazon Amazon
It's a nice piece. The 2" ID was a smidge too large for my liking, and I had to add a bit of extra rubber insulation to make the fit on the send unit really snug. YMMV with the Marshall send unit though.
I haven't thought about or researched water temp sensor locations, but my gut reaction is to cut and add a new coupler to the top rad hose with the specific fitting you need for the sensor. Something like this:
https://www.mishimoto.com/mishimoto-...gaArZuEALw_wcB
Old Jul 23, 2020 | 11:15 PM
Serafin's Avatar
Serafin
Thank You I’ll be using the prosport gauges. Hope it’s around that size.
ya i saw that for the water temp. But I’ll loose the bleeding screw if i replace that area.
Old Jul 24, 2020 | 12:06 PM
Tragesaurusrex
I meant I would cut a section of the rad hose out and add a new fitting coupler to the top radiator hose, not replace the bleed valve coupler. A little bit upstream of the bleed valve coupler seems like the best place, as long as you're mindful of the T-MAP sensor. Downstream of the bleed valve coupler looks like it'd be a little tight.
Old Jul 24, 2020 | 02:01 PM
Serafin's Avatar
Serafin
ahh good call. I was just gonna use the sender to bleed. But that will work. You happen to know the radiator inside diameter size? 52mm?
bluescreen
How to
Jun 18, 2019 09:42 PM
not-so-rednwhitecooper
Dec 23, 2011 06:24 PM
minikania
22
Apr 2, 2011 09:00 AM
kriation
15
May 17, 2008 09:41 AM
