R50/53 R53 Connector flange to WP connection question
Old May 16, 2020 | 06:32 AM
BoostedBlueToyotas's Avatar
BoostedBlueToyotas
I am in process of replacing WP and changing supercharger oil in my MINI. I replaced the connector flange between engine block and water pump. Unfortunately I did not take pictures of the flange before removing WP. Now that I have the supercharger back on I am not sure if I have the SC pipe seated correctly in the flange. In my case
I can see part of the O-ring that seals the two. Not sure if this is correct or if the O-ring rolled when installed the supercharger. Pictures of how mine currently looks.
Rather not put it back together and find out that I have a massive leak . Does this appear correct or did I goof?
Old Jun 7, 2020 | 02:12 PM
GearheadS's Avatar
GearheadS
Sorry this is kinda late, but it should not be visible like that. Seems like something isn't seated completely.
Old Jun 7, 2020 | 04:47 PM
BoostedBlueToyotas
Yep it wasnt correct. I got more confirmation when I looked at water hose from WP to hard line under the thermostat. It was stretched to far and obviously not correct. So I pulled the Supercharger and got it lined up right.
But I then decided to replace that hose so I have to pull it again :(. Thanks for the reply, I was going to update this after I got done
Fanopj1
Jun 7, 2020 05:09 PM
doctahjones
R60/R61 Stock Problems/Issues
Feb 26, 2020 12:41 PM
surferma4
Mar 22, 2018 11:38 AM
Doc Pain
Mar 14, 2016 09:01 AM
jblow
Dec 3, 2008 08:47 AM
