R50/53 oil in fuse box???? any ideas?
Old Apr 21, 2020 | 08:12 AM
geoff0076's Avatar
geoff0076
Hi there,
I am in the process of replacing my fuse box by the drivers left kick panel (I broke the k42 horn relay, did not know it did not come out). Anyway, could have been worse as it seems I can get a used one for a reasonable price.
As I pulled the larger colored plug-ins out on the back side of the existing fuse box, I saw some oil (at least that is what I think it is) in and around 3 of the 10 ports(?) and also on the end of the plug ins. The ones affected were black, green (top and second right) and pink (top left).
Any idea what this is, why it is there, and if signifies a bigger issue? There is no oil anywhere else near the box or on any of the wires coming in.
Thanks for the insights.
Old Apr 21, 2020 | 08:29 AM
MVPeters's Avatar
MVPeters
Could it be dielectric grease or some kind of waterproofing?
Old Apr 21, 2020 | 10:09 AM
geoff0076's Avatar
geoff0076
That is what I was hoping, but found it strange not to be on all of them.
I emailed the shop that did the rebuild on it after a fire required replacement of the wiring harness....I'll post if I get anything concrete.
Thank you for your time and thoughts on this.
Old Apr 21, 2020 | 10:39 AM
A383Wing's Avatar
A383Wing
I have had this happen before. Your oil sender switch is probably bad. What happens is if the sender is leaking where the electrical connector is, the oil pressure will push oil up the inside of the sender wire. Pull your electrical connector off of the switch and see if there's any oil inside
Bryan
Old Apr 21, 2020 | 11:24 AM
geoff0076's Avatar
geoff0076
Bryan,
Thank you. I just replaced the oil switch today as part of an earlier issue with the low oil pressure light coming on. When I pulled the connector, it was full of oil.
I will just blow the old fuse plugs out a bit with compressed air prior to plugging them back into the new fuse panel (which is on order).
Its crazy what you find when you start digging into these cars! Better to know than not know.
Thank you!
Old Apr 21, 2020 | 12:17 PM
A383Wing's Avatar
A383Wing
Spray some brake clean or some contact cleaner where the oil is... otherwise if you just blow it with the air hose, you will just spread the oil out
Bryan
Old Apr 21, 2020 | 01:36 PM
geoff0076's Avatar
geoff0076
ok...I did that with the oil pressure switch...good call, I will do the same with these connectors.
Should get the parts tomorrow and be back on the windy road soon!
Old Apr 21, 2020 | 04:10 PM
Da_Ghost's Avatar
Da_Ghost
Chrysler is kinda infamous for that. It's called capillary action or wicking, it doesn't need pressure and can go up as it does not care for silly things like gravity.
Old Apr 22, 2020 | 12:02 PM
Seen this oil wick on the n18 engines, have not seen many on the gen 1. Thanks for posting up the pics.
Old May 28, 2020 | 12:40 PM
ChrisOhle's Avatar
ChrisOhle
I'm chasing an electrical issue on a "project" R50. I'm going to pull the interior fuse panel this weekend to see if there is any oil like this...my question is: can this oil cause electrical shorts...is there enough conductivity in old oil to cause electrical interference and shorts?
Old May 28, 2020 | 12:58 PM
geoff0076's Avatar
geoff0076
Chris, I started the thread and the crew here helped me get it explained and fixed. I was not having any electrical issues when I discovered the oil in my fuse box. I can't answer your question with any degree of certainty, but I am sure someone on this thread or part of the community will help. Best of luck!
pkunk
R55 :: Clubman Talk (2008+)
Dec 15, 2022 01:42 AM
GregoryK
May 27, 2014 03:56 PM
rbb
Sep 24, 2011 11:29 AM
Latka
Classic Mini Talk
Aug 14, 2007 07:24 AM
skitelluride531
Jul 15, 2006 03:16 PM
