R50/53 Bottom Reverse Light
Hey, I have a 2006 Mini Cooper S.
So you know how on the earlier ones the reverse light was on the bottom in the middle of the back bumper. Well, I was wondering if there was a way to add that to my 2006 instead of using the reverse light in the taillights. I just like the other look so much better.
Thank you
Thank you
Thank you
Thank you
Mine has full euro spec dual rear fogs in the taillights with the full switches in the center console, and the back up light in the lower center, but it is a 2003. It was done by the previous owner. Good luck in you search.
Yes it's the same as adding a rear fog. So you just need to get the early reverse light
https://www.waymotorworks.com/revers...t-r50-r53.html
And since it is a late R53 it already has the connector and wiring for the rear fog. So you can just cut those wires and tap them into the reverse wire. I do it on the pass side since that is where the wires run into the body by the tail light already. I like to cut them so you don't back feed voltage to the BC1 on the rear fog circuit.
Any recommendations on the best way to do this? I'm new to working on cars and do not a whole lot and would love some guidance.
Thank you
got_mini?
Oct 21, 2015 05:45 AM
johnhardy1
R55 :: Clubman Talk (2008+)
27
Feb 3, 2012 05:02 AM
