R52 Help Loss of power New R52 owner.
I have a 2005 MCS I got it for my daughter to learn to drive on a stick shift, secretly I always wanted one so I dive it often.
. I was driving on the highway and the car just all of a sudden it lost almost all power. It takes forever for the rpms to rise, and it has zero power it's like the supercharger isn't spinning but it is. I just can't tell if its the pulley or the bypass valve is not closing fully.
I got the codes off the ecu.
p1688
p0341
p0108
Thanks in advance,
Sean
. I was driving on the highway and the car just all of a sudden it lost almost all power. It takes forever for the rpms to rise, and it has zero power it's like the supercharger isn't spinning but it is. I just can't tell if its the pulley or the bypass valve is not closing fully.I got the codes off the ecu.
p1688
p0341
p0108
Thanks in advance,
Sean
You'd know, it wouldn't RPM at all under throttle of any kind.
The codes are:
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0341 Crankshaft Position Sensor 'A' Circuit Range/Performance (Bank 1 or Single Sensor)
P1688 Electronic Throttle Control Monitor Level 2/3 Air Mass Flow Calculation Error
I'm thinking Crank Pulley, if it's the stock one and the car has over 75k, it's a good bet.
The codes are:
The codes are:
The codes are:
b18b1ex
20
Sep 28, 2019 04:51 PM
