R50/53 Pretty advanced technology for 2002
Old Jun 23, 2019 | 08:02 PM
Island_Moose's Avatar
Island_Moose
I've discovered the previous owner of my 2002 MCS selected a factory option that I was previously unaware of, specifically the Automatic Oil Replacement System or AORS.
Effectively how it works is that the dealership initially adds the recommended volume of engine oil when the vehicle is new, then from that point onward the vehicle works automatically with the owner to constantly replace the oil. Using a cleverly-engineered gap in the timing chain cover seal, engine oil is slowly purged from the system as it ages, and the owner simply needs to add an equivalent amount weekly through the normal oil filler cap at the top of the engine. The purged oil continues to add value by preventing corrosion on the underbody of the car as it is dispersed widely under normal driving conditions.
Using this ingenious technology the engine is always running with fresh oil, needing only a filter from time to time.
Hats off to those clever buggers at BMW!
Old Jun 24, 2019 | 12:20 PM
Andy_S's Avatar
Andy_S
This was nothing new in 2002. This is just a slight modification to a feature that has been present in all Minis since 1959. Only the exact location(s) of the cleverly designed purge holes varies.
Old Jun 24, 2019 | 12:41 PM
A383Wing's Avatar
A383Wing
My wife's PT Cruiser is the same way...it's a 2003, and we bought it new......I'm now adding about 1-2 quarts of oil between each 3,000 mile oil changes......and it's not leaking at all...the engine is eating the oil rather than dumping it on the ground......but there is no noticeable "blue oil smoke" out the tail pipe that I can see......so it's eating it at a slow rate at this point.....
Bryan
Old Jun 24, 2019 | 01:04 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Its British. If there's no oil under them, there's no oil in them!
Old Jun 24, 2019 | 03:26 PM
Blue R50's Avatar
Blue R50
It's a 17 year old car. They all leak by that age, no matter who makes them. If it leaks and is less than 10 years old then there's an issue. Anything rubber or plastic turns to crap over time, including safety items like brake hoses and fuel lines. Be sure to check them, and check your coolant hoses on your leaky old MINI while you're at it! Oil leaks destroy them and can lead to a catastrophic failure.
Old Jun 25, 2019 | 07:30 AM
gumbedamit's Avatar
gumbedamit
My 2001 Ford E-250 is Bone dry at 250K miles.
Never replaced any seal, O-ring or gasket.
Old Jun 25, 2019 | 08:17 AM
Oldboy Speedwell's Avatar
Oldboy Speedwell
Island_Moose,
very well written and clever.
Much enjoyed.
Well done!
Now,
we need some mugs made up with the MINI wings...
IzzyG
Dec 31, 2008 02:40 PM
Silkworm
Jan 13, 2008 06:08 PM
flannelhippie
MINI Camera and Video
23
Sep 19, 2006 07:02 PM
markbradford
Chicago MINI Motoring Club
Oct 6, 2005 09:21 PM
Mark
Jul 15, 2005 07:08 AM
