R50/53 Adding water temp gauge?
#26
Did your car not come with one? Or... did you remove it? If you removed it, no wonder why you're against inline radiator temp sensors...
Of course, the ideal spot is someone on the block/head in a water jacket, but that isn't always feasible.
Thus, the rad hose is better than removing the OEM gauge and having nothing (lol), or trying to get actual temp numbers from the OEM gauge.
For my other car, I have both the ECT sensor and a sensor tapped/drilled into a water neck on the head, both being displayed to a PLX gauge. OP, if you wanna do it right ... do it right the first time. Otherwise, like I said, the easy button is the rad hose and don't be an idiot and remove the OEM gauge.
The "easy button" way for you may be the rad hose, but that is entirely the wrong place to put the sender....and if you want to keep calling me an idiot, you better have all your facts straight about members and their cars before calling someone out on an open forum.....
Bryan
#27
#28
Bryan
#29
Is the hose sender adapter really that bad of a place to install a temp gauge sender? Regardless of where it is in the coolant system? They can be placed just about anywhere with ~3.4" of straight hose. Of course figuring that the t-stat is operating as normal.
We haven't had any direct mentions of issues or complaints about the operation of any of our gauge kits, but we're always hungry for more information.
#30
The "ideal" place is in the block or cylinder head before the t-stat....that way you can see the water temp rise as the car warms up. If it's mounted in the radiator hose, it won't show a warm or hot reading until the t-stat opens....if it even does....and if it sticks shut, you won't be able to tell how warm the water temp is because all the hot water is still in the engine block and head.....while your temp gauge still reads "cold"......and now your engine is in meltdown mode
Again.....all vehicle manufacturers put the temp gauge senders before the t-stat for this very reason.....for those that think it's OK to put the sender after the t-stat, I sure would not want them working on anything I own
Bryan
#31
Consider a factory setup.
You have at least an idiot light, but most have a gauge and the light.
If you have a stuck t-stat... you won't know anything is wrong until the gauge is pegging the hot side and/or the idiot light is on.
Now, you add a sensor in the rad hose.
You still won't know if the t-stat is stuck closed. Nothing has changed.
However, assuming you don't have a t-stat that sticks closed every other week, you now have a slightly better idea of what the water temps are going thru the rad and you still have the OEM warnings to warn you of impeding doom.
Overall, the rad hose is a bandaid location for the water temp, for reasons as described by A383.
But, if your options are either a less-than-ideal location or none at all, I'll go with the less-than-ideal approach. Least you have SOME idea of what the water temps are.
#32
I have the Scangauge II in my car set to display water and intake temps, if you don’t mind digital readouts or having something plugged into your OBD port all the time.
#33
#34
#35
The reason BMW dumbed down the temp gauge reporting is because of ignorant owners. That's why we can't have nice things. Oh, and fake oil pressure gauge is not unique to Mini. Same reason we can't have nice things.
#36
So could go either way, but all the other bolt boss's are metric as well.
#37
The oil pressure switch is not BPT. I had gone down that road before. It is American PT. It uses exact same part as on a lot of Dodge cars/vans. I agree it is the filter housing which is unique so not something you want to extend to the water temperature sensor that is mounted to the head. But still it is just a casted hole and can be taped for any thread.
#38
#40
#41
#42
Because for some of us, tying up the phone is a real PITA, not to mention having to keep the app in the foreground. Just the fact that you have to mess with the phone while driving is enough to not consider as it is illegal in most states. And for me too many things competing for the access to OBD. Even with the multi-device harness most don't play nice with others. Most of these BT dongles are more trouble than they are worth. If you want the least of fuss get a good old hard wired OBD gauge. I prefer UtlraGauge for its display quality but I don't have one for the Mini as there are too many competition for the OBD port.
#43
Besides that, there are a lot of people who use the OBD to display the engine parameters, with many using the Torque app. The only real downside I can see is you need to have a separate gauge(s) for sensors the engine doesn't track -- wideband AFR, oil temp, etc. Still, better than nothing.
#44
Oh jesus, you're gonna infuriate the forum's know-it-all, thankfully, it's easy to put him (Pnw...something) on ignore.
#46
Bryan
#47
#48
not-so-rednwhitecooper
12-23-2011 06:24 PM
minikania
22
04-02-2011 09:00 AM
early_apex
12-27-2003 01:00 PM
perfpow
05-20-2003 10:50 PM
