R50/53 Chatter noise at idle?
Old Jun 16, 2019 | 02:17 PM
alconk's Avatar
alconk
I got out of the car today and left it running and could hear a chatter noise from the engine compartment but as soon as I depressed the clutch in it went away. Is that a throw out bearing going bad?
Old Jun 17, 2019 | 03:58 AM
veedubpat's Avatar
veedubpat
Throwout bearings sound very scratchy, not rattly. Does your car have a single-mass flywheel conversion / lightweight flywheel?
Old Jun 17, 2019 | 08:55 AM
alconk's Avatar
alconk
Good question I don’t know? How can you tell the difference? I know lately I have been having trouble going into 1st and reverse.
Old Jun 18, 2019 | 07:48 AM
JABowders's Avatar
JABowders
Veteran: Army
Differently sounds like you need to look at the clutch assembly (throwout bearing,clutch plate, pressure plate, slave cylinder, and flywheel).
Best of luck.
Motor On!
Old Jun 18, 2019 | 07:53 AM
JAB 67's Avatar
JAB 67
I am reasonably certain that you are experiencing the same sound as am I. It is most likely the sound that dual mass flywheels make as they age; depress the clutch and the sound goes away. I don't yet full understand what is going on, but I have lived with it for many years and many many miles.
Old Jun 18, 2019 | 08:18 AM
alconk's Avatar
alconk
Best of luck.
Motor On!
Thanks! I have lately been experiencing trouble going into first gear and reverse. It’s alm like I have to force it in.
Old Jun 19, 2019 | 03:58 AM
RudeJoe's Avatar
RudeJoe
Could be the shift linkage. The transmission end of the cables have ball and socket connection. The socket is on the cable and is :suspended" in a rubber bushing. That bushing can break down and then the cable isn't able to move the socket and ultimately more the shift lever on the transmission. Check the cables at the trans.
Old Jun 19, 2019 | 08:42 AM
alconk's Avatar
alconk
Ok will do thanks!
amarr003
Aug 7, 2014 10:44 AM
dualshowman66
Oct 18, 2013 07:10 AM
Miami
26
Nov 13, 2012 02:39 PM
Big Poppa
Aug 30, 2005 08:19 AM
