R50/53 chain tensioner question
Old May 12, 2019 | 10:46 PM
Zac_r53's Avatar
Zac_r53
i know the timing chain tensioners are an issue with r53's but figured id ask ive had my r53 for little over a year now and ive put about 35k miles on it, though ive always had some chain noise only at idle i had the chain and tensioner replaced when i picked it up and ive tried a few different tensioners hoping to solve the issue but it still makes noise is there an actual fix for this?? i can get it to stop if i push in the clutch about a 1/4 of the way and let it back out, or if its all the way in it doesnt make any noise, each time ive replaced the tensioner it will be fine for a day then make noise again
Old May 13, 2019 | 02:57 AM
JKo's Avatar
JKo
The issue is probably elsewhere if depressing the clutch makes the noise go away...
Old May 13, 2019 | 05:09 AM
BlwnAway's Avatar
BlwnAway
Agreed, you may have unfortunately been chasing the wrong issue.
It sounds like throwout bearing noise, some Mini's do it worse than others, but it is a well known nuisance item with OEM clutch setups.
And it is just that under most circumstances, just a nuisance, normally doesn't effect longevity of the bearing or clutch.
Old May 13, 2019 | 06:06 AM
JAB 67's Avatar
JAB 67
May also be the noise that OE dual mass flywheels make.
Old May 13, 2019 | 08:26 AM
Zac_r53's Avatar
Zac_r53
Old May 14, 2019 | 09:57 PM
Zac_r53's Avatar
Zac_r53
any ideas?
daonlyillwiz
Feb 4, 2014 06:28 PM
alinfante
R55 :: Clubman Talk (2008+)
Oct 29, 2013 07:54 AM
Chris Nord
Aug 14, 2013 12:48 PM
gbfan10
23
Dec 12, 2012 08:26 PM
realeyezsoul
Oct 30, 2012 02:45 PM
