R50/53 R53 Auxiliary Light relay check?
Old Apr 9, 2019 | 10:51 PM
alconk's Avatar
alconk
How can I tell if the green large relay is working? There are several terminals I think 8 and this powers the optional driving lights in the grille. The switch lights up when depressed but lights do not work and are new. The two wires going to the light are red and brown so I have the red going to the light and the brown going to the ground. When I pull the relay it removed the power from the switch so that tells me power is going through it.
Old Apr 10, 2019 | 04:24 AM
Capt_bj's Avatar
Capt_bj
you do know that the rally lights, when activated, will only come on with the high beams (assuming they are wired according to the factory instructions)
the switch light ON means they are activated .... but will only come on with the HIGH beams
when the ignition is switched off they will deactivate . . .
AND I'd check the inline fuse on the power wire .....
https://www.minimania.com/pdfile/NMA3030_INSTR.zip
Old Apr 10, 2019 | 04:36 PM
alconk's Avatar
alconk
Oh boy I feel like a dummy! No I didn’t know that so I went out and checked and sure enough they work. Thank you! Is there a way to switch out that bulb for a led?
Old Apr 11, 2019 | 09:30 AM
Capt_bj's Avatar
Capt_bj
the instructions I linked say the bulb is 55 W H3, and show you how to change
pretty standard size
Old Apr 17, 2019 | 12:30 PM
JABowders's Avatar
JABowders
Veteran: Army
There are LED conversions bulbs available out there, but I don't know if they will fit in the light housing like this ...
EXAMPLE: https://kensun.com/products/led_kit_...ith_cree_chips
But these look like they might work... https://www.ledperf.co.uk/h3-high-po...=-966_969.html
these are only EXAMPLES, I do not endorse or recommend these products. I have not messed with mine or bothered to swap out my standard H3s so I have no clue on how well they work.
Best of Luck.
Motor On!
themarques
Mar 21, 2023 11:29 AM
wsalopek
Dec 12, 2017 10:56 AM
ProfessorDave
Apr 14, 2006 09:42 AM
