R50/53 Yellow high beams
Yellow high beams
2005 hatchback has annoying yellow high beams.Looking to change the bulbs to white light. I believe the bulbs are H9 type. Any suggestions?
They should be H7's,
There are these:
https://www.amazon.com/White-Halogen...39145650&psc=1
Or look at the Silver Star, if you want to stick with halogen.
There are these:
Right now GE makes the brightest H7 that is safe to use in OE-replacement applications:
I wouldn't run a 100w anything in OE housings with OE wiring. Or anything over the factory 55w without relayed harnesses at the very least.
Right now GE makes the brightest H7 that is safe to use in OE-replacement applications: https://www.amazon.com/dp/B00GZHC2EE/?tag=2402507-20
But honestly, that was just the first LED replacement that came up on search.
If you want to see where you're going, put in GE, Sylvania or Philips H7 bulbs.
Philips will last the longest.
If you don't want to see where you're going & do want to blind everybody else, put in the LEDs.
It would be nice to hear from others on this...
I've got some 75w equivalent LED's and I think they work as well or better than the SilverStar's I used to have. But maybe it's just me...
(I can't for the life of me remember where I got them)
And blinding others really shouldn't come into play here, so I don't worry about that.
Makes sense on how it was carefully selected now! :laugh:
StarlightBlueOxford
Jul 19, 2019 04:36 AM
