R50/53 Can't manually open hatch
Old Feb 5, 2019 | 02:27 PM
k1ng's Avatar
k1ng
My 2005 R53 needed a new battery so I removed the battery and closed the trunk while I went to get a replacement. Now I can't open the hatch manually. I pulled the hatch release cable under the seat and it sounds like the hatch being released, but I still can't open the hatch. It releases just a little bit where I can get my fingers under the hatch door, but it doesn't fully release. I tried pushing it back down and tried it again (several times), but no luck.
Any idea what else I can try?
Thanks!
Old Feb 5, 2019 | 03:10 PM
MVPeters's Avatar
MVPeters
With jumper cables, connect the new battery to the +battery connection under the hood & a good ground.
Then, if it worked before, the electric hatch button or the key fob will work.
Old Feb 5, 2019 | 03:52 PM
k1ng's Avatar
k1ng
Nice tip! That got me back up and running. The "trunk is open" light is on, however, even though I closed it securely. I tried turning the car on/off and opening/closing the trunk. If you have another tip for this, that would be awesome. Either way, I really appreciate your help!
Old Feb 5, 2019 | 05:17 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Disconnect then re-connect the battery and see if the "trunk is open light" will go out when you close the rear hatch.
houlster
R55 :: Clubman Talk (2008+)
64
Dec 10, 2022 11:20 AM
MitchV
R60/R61 Stock Problems/Issues
Jun 2, 2022 04:00 PM
777madmax
Aug 18, 2017 04:35 PM
puwit321
Jun 22, 2005 04:50 AM
