R50/53 TorquePro PIDS
Old Jan 27, 2019 | 12:02 PM
mattmorr's Avatar
mattmorr
TorquePro PIDS
Has anyone used Torque Pro and installed custom gauges to display additional info?
I've searched and all i've found is an old thread that includes this info:[size=3]IDs supported by MINI Cooper 2002
Service 1 PIDs
PID Sensor Returned value
00 PIDs supported H'BE3EB811
B'10111110001111101011100000010001
1,3,4,5,6,7,B,C,D,E,F,11,13,14,15,1C,20
01 System tests status
03 Fuel system status 0x01 = Open loop
0x02 = Closed loop using O2
0x04 = Open loop driving conditions
0x10 = Open loop system fault
0x20 = Closed loop but system fault
04 Calculated Load Value 0% to 100% 100% = 0xFF
05 Engine Coolant Temp Degree C + 40
06 Short Term Fuel Trim -100% to +99.22% (0% = 0x80)
07 Long Term Fuel Trim -100% to +99.22% (0% = 0x80)
0B Intake Manifold Pressure kPa
0C Engine RPM RPM*4
0D Vehicle Speed KM
0E Ignition Timing Advance 0.5 degree-per-bit 0.0 degree=0x80
0F Air Intake Temperature Degree C + 40
11 Absolute Throttle Position 0%-100% 100%=0xFF
13 Location of O2 sensor
14 O2 Sensor 1 Voltage & Short-term trim -100% to +99.22%
15 O2 Sensor 2 Voltage & Short-term trim -100% to +99.22%
1C OBD standard
20 More PIDs 80000000
21 KM travelled while MIL lit[/size]
2006 MCS BRG - Detroit Tuned bypass, Alta belt tensioner, ATI harmonic balancer, lotsa o-rings and rtv
Old Jan 31, 2019 | 10:14 AM
IQRaceworks's Avatar
IQRaceworks
I'm interested in this also. I use TorquePRO for my diesel truck....works great. But for the MINI, it seems to only have a few PID's that work. I'd love to know how to set up more custom PID's in order to monitor more engine parameters.
Old Jan 31, 2019 | 12:22 PM
MrGrumpy's Avatar
MrGrumpy
I have a bunch of custom gauges on dash command, I know they are similar, but not the same. With dash command I can get nearly every PID they have in my ‘12. I would think something like torque pro would have all sorts of PID’s to choose from. I have a gauge for everything from coolant temp to fuel rail pressure and ambient air temp to timing advance and so on. Almost anything you can think of. Screen real estate becomes the biggest issue for me. Good luck with it!
miniuy
Oct 7, 2016 12:09 PM
actarus
Electrical
May 4, 2016 03:14 PM
Systemlord
Jul 25, 2015 10:06 AM
ggcadc
Electrical
Apr 8, 2011 03:17 PM
