R50/53 daytime running lights question
Old Nov 5, 2004 | 02:20 PM
gr8britwjh's Avatar
gr8britwjh
Have just picked up our new MCS. Supposedly the daytime running lights have been programmed by the dealer, but I'm not sure whether they are working properly (and the instruction manual is pretty ambiguous).
So, with the headlight stalk in position 0 or 1 and the key turned to position 2 or 3, we have dim illumination at the front (not the bright bluish low-beam xenons; these are only activated with the light stalk in position 2) but no illumination whatsoever at the rear. Does this sound right for daytime running lights ? I would have expected lights at both the front and rear to be activated ?
Old Nov 5, 2004 | 02:27 PM
DrkSlvrS's Avatar
DrkSlvrS
That is the correct configuration (at least that's the way it is in my '02).
The DRL's use your high beam at a 50% power reduction.
No tail lights or side markers.
You'll get the warning gong if you leave the switch in position 1 and turn the ignition off and pull the key.
Also, your high beams will not stay on (excellent for flashing on-coming MINI's).
Old Nov 5, 2004 | 03:20 PM
gr8britwjh's Avatar
gr8britwjh
DrkSlvrS,
Thanks for such a quick and reassuring reply. This is our first car with DRLs so I wasn't sure what to expect. Only done 100 miles so far, and loving it to bits. Can't wait for the run-in period to end .
Old Nov 5, 2004 | 05:16 PM
lotsie's Avatar
lotsie
On my 03 the DRL don't come on till you release the e-brake.Keep that in mind when it is cold out,no point having the headlights on while tiring to crank it over when cold.
Happy motoring
Alkaidovich
Jan 30, 2021 01:35 AM
jeffbeckhudd
Aug 29, 2015 09:11 PM
oldkid6
Aug 11, 2015 08:13 PM
jrezzo
Aug 9, 2015 10:32 PM
