R50/53 Any subframe or Control Arm differences 2003 vs 2006?
Old Mar 17, 2018 | 11:36 PM
Spank's Avatar
Spank
I've got a 2006 with bend front subframe and passenger lower control arm. Local auto salvage has a 2003 with a good subframe and lower control arm.
I plan on swapping over all the other bits attached like swaybar and steering rack. Just wondering if the actual subframes and/or lower control arms have any differences between early R50 and late R50
Old Mar 19, 2018 | 03:51 PM
Whine not Walnuts's Avatar
Whine not Walnuts
The best way to check this out is by using RealOEM. You select your model, year and month built to pull up templates of all the parts and the part numbers. You can then check you parts against a different year.
Old Mar 19, 2018 | 07:18 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The subframe and control arms are the same so you are good.
But don't put the stock control arm bushings back. Go ahead and upgrade to the powerflex so you never have to do it again.
https://www.waymotorworks.com/powerf...shing-kit.html
CSP
Mar 2, 2017 01:57 PM
bimmadave
Nov 12, 2016 02:46 PM
cargusjoh
May 31, 2016 09:55 AM
prb44t
Classic Mini Talk
Jul 14, 2011 08:43 AM
Phantom
Sep 11, 2010 10:51 AM
