R50/53 Help buying 2006 MCS with 20k miles
Old Oct 7, 2016 | 11:17 PM
Michael Canger's Avatar
Michael Canger
Hi everyone, I'm considering getting back into a mini, and I found what I think is an immaculate car. I've looked through the forums and refreshed myself on the common issues. I'm wondering if anyone could lend their opinion on purchasing a mini with under 20k miles. I'm concerned about dried up seals and problems from simply not using the car enough. Am I crazy or does anyone think that could be an issue? Any advice would be greatly appreciated!
Old Oct 8, 2016 | 02:21 PM
Baggerbleu's Avatar
Baggerbleu
I purchased a 04 JCW last July. Less than 8700 miles, thought it was running great and it was except I had to replace the control arm bushings. Then the supercharger started making noise and I just finished installing a new one. Low miles are great for some wear and tear items but not all. Been there and done that. I'm not familiar with the 06 models as mine is a 04, but driver convenious items were important to me, like Bluetooth. 04 models did not come with it.
Old Oct 8, 2016 | 02:55 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
It all depends on how the vehicle was maintained, stored, how often it was driven and for how long. If in a humidity and temperature controlled environment, battery tender hooked up, driven periodically for at least 15-30 minutes at a time and A/C cycled, then there's a good possibility it could be relatively trouble-free if oil was changed annually and coolant was changed every 2-3 years.
Old Oct 8, 2016 | 03:08 PM
Mini Mania's Avatar
2006 mcs r53
Good points, all. Mine is also an '04 R53. Bought it this Spring with 79,000 miles. It was well maintained and obviously garaged. Though it spent most of its life in Texas, where I was concerned the heat would dry things out, it actually was in great shape. Test drives and an inspection by a mechanic familiar with MINIs should help you make a decision.
Holiday MINI Gifts
Old Oct 10, 2016 | 07:30 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Less than 20k, buy that car. Even if you have to do a few seals having a good low mileage car would be ideal, but doubt you'd have to do much at all. We always recommend having a shop inspect it first, but sounds like an easy check over.
Old Oct 10, 2016 | 08:31 PM
jeffl's Avatar
jeffl
20k. Cool and I thought mine was a low mileage car at 47k on a 05 cooper S, but it was rode hard and put away wet. I just got it running after rebuilding the engine.
Old Oct 11, 2016 | 06:02 AM
Goldsmithy's Avatar
Goldsmithy
MINI Alliance Ambassador
I bought my 2005 /r52 in April 2015 with 3,648 original miles, BUT, it was kept in a garage in Key Largo, Fl. I had to replace the foam between the radiator and the support, and the tires as they were 10 years old. I am watching for other rubber parts to fail. I have put about 11,000 miles on the car and everything appears to be in good shape. It shows wear on the top and I have replaced the top/body molding. I have never had sooooo much fun with a car.
Old Oct 13, 2016 | 09:52 AM
Kief's Avatar
Kief
Wow OP 20k is low!
I just picked up my '06 yesterday with 61k, and I thought that was low
PPI discovered some typical (I think) wear items which need to be addressed:
upper strut mount
lower control arm bushings
thermostat
Attached Thumbnails Help buying 2006 MCS with 20k miles-img_4080.jpg   Help buying 2006 MCS with 20k miles-img_4044.jpg
Old Oct 13, 2016 | 02:44 PM
Mini Mania's Avatar
R53
Originally Posted by Kief
Wow OP 20k is low!
upper strut mount
thermostat
Wow, congrats Kief and welcome to NAM. You have quite a find there! Beautiful.
Check our site for service, maintenance, and performance upgrade guides.
As for your upcoming plans:
Strut mount:
http://new.minimania.com/Mini_Cooper...lication_Guide
Control arm bushings (go Poly):
http://new.minimania.com/Search_Resu...shings/default
Thermostat:
http://new.minimania.com/Mini_Cooper...lication_Chart
Highly recommend Sprint Booster to fix the drive-by-wire throttle lag:
http://new.minimania.com/Search_Resu...ooster/default
Free shipping on Sprint Booster this month. Any questions, please let us know!
Old Oct 13, 2016 | 03:47 PM
Kief's Avatar
Kief
Strut mount:
Thermostat:
Thank you for the links
Do you think this is a fair estimate
https://www.northamericanmotoring.com/forums/r50-r53-hatch-talk-2002-2006/307860-findings-after-ppi.html
Old Oct 13, 2016 | 06:04 PM
Mark97xp's Avatar
Mark97xp
Picked up my 03 a couple years ago with 42k on it. 👍
Attached Thumbnails Help buying 2006 MCS with 20k miles-image-2220723388.jpg
Old Oct 13, 2016 | 10:24 PM
Michael Canger
Thanks for all of your comments and advice everyone. I'm happy to report that after hearing others have had good experiences with low mileage minis I pulled the trigger on her! 2006 MCS with 9800 miles! My Hyper Blue Unicorn with pure silver roof!
I've arranged an inspection and recall appointment so I'll have more of an idea what's up with her next week. I shared the same thoughts and sentiment with the previous poster that said "under 20k buy that car."
The dealership offered a 30 day powertrain warranty and equal length return policy as well. So the worst case scenario will be having to sink money into it on day 31. I'll take that chance!
As far as issues, there is one main one. I have noticed the engine temp gets hot at idle after its warmed up. From what the service dept at my local mini dealership said, it's a secondary fan that runs at idle. A quick 50 foot drive seems to switch a fan on that immediately cools it down.
I haven't researched this yet since there's no issue at red lights or stops under a minute. So I'm trying to do my best at what every new mini owner does, keep motoring
The other drawback is lack of a few options that would have been nice. No Harmon Kardon (unless the later r53 doesn't have the H/k badge), no aux input, don't believe I feel an LSD, no dimming mirror. If I had my druthers I'd have those things but beggers can't be choosers. Frankly an LSD is all I'd really want.
Going on a road trip tomorrow from NYC to Buffalo. I'll post some pics for viewing pleasure. Thanks again everyone for all of your input.
Old Oct 14, 2016 | 10:17 PM
Mini Mania's Avatar
R53
Sounds great, looking forward to the photos!
Old Oct 15, 2016 | 06:54 AM
Michael Canger
Old Oct 15, 2016 | 06:56 AM
Kief's Avatar
Kief
Looks good. Congrats!
Old Oct 17, 2016 | 01:26 PM
Mini Mania's Avatar
R53
Yes, definitely looks great. Thanks for sharing!
Old Oct 17, 2016 | 11:52 PM
RB-MINI's Avatar
RB-MINI
Welcome and congratulations! You basically have a brand new, 10 year old car. What a great find!
You can run the VIN through one of the online decoders to find out all of the options your car has and the color. In the pics it looks like Space Blue which often had silver roofs.
Old Oct 18, 2016 | 04:41 AM
mdaz75's Avatar
mdaz75
Nice, welcome to the forum!
Old Oct 18, 2016 | 11:10 PM
Mini Mania's Avatar
VIN Decoder
Here's a good VIN Decoder:
https://www.bmwvin.com/
TJANK
Jul 31, 2019 06:23 AM
TJANK
Aug 18, 2016 02:55 AM
Russter500
Aug 17, 2016 06:51 AM
TJANK
Aug 15, 2016 11:28 AM
TJANK
Aug 10, 2016 11:46 AM
