R50/53 CVT Removal
Old Jul 14, 2016 | 07:05 AM
John Roberts's Avatar
John Roberts
CVT Removal
Hi all Im removing the CVT from a 2003 Mini Cooper Non S. Trans self destructed befor I bought the car (very cheap) and I have sourced a replacemant trans. However the engine only spins a few degrees. It looks all good timing chain still in situ no metal in the oil etc, so I assume part of the trans has jammed up in the flywheel/ringgear.
Is there a regular torque converter or what goes between the engine and CVT? If I can split the engine and trans it should free up, just cant see how to do it as the cvt is still in the car and attached, all help appreciated
Old Jul 14, 2016 | 12:06 PM
nkfry's Avatar
nkfry
There is an input shaft on the transmission that engages the flywheel, if the trans is locked you won't be able to turn the engine over with them still mated.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jul 14, 2016 | 04:51 PM
John Roberts
Many thanks. So will the flywheel come out with the trans in one unit by sliding off the spline?
moremini
Apr 20, 2016 07:08 AM
JWA
Mar 20, 2016 04:29 PM
murphythemini
Mar 19, 2016 02:45 PM
miniminimini
Jul 11, 2002 09:49 PM
miniminimini
Jun 17, 2002 09:19 AM
