R50/53 Update on cyl 2 missfire
Old Jan 28, 2016 | 05:58 PM
04ChiliRedMCS's Avatar
04ChiliRedMCS
Just updating on my MCS. Was having a p0302 code(cylinder 2 misfire) recently in the cold weather. Replace plugs and was ok? ,still had slightly rough idle . Then before the recent snow storm it started on 3 cylinders and then stalled and restarted fine. So I bit the bullet and bought 380 cc injectors, same price as standard. Took about an hour to install . On start up ran great ,let sit overnight outside in under 30 degrees. the next day start up was good ,smoother idle just running much better. So it looks like an injector was not working right. Seems like it is good now but keeping fingers crossed.
Old Jan 29, 2016 | 08:45 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Assuming you cleared all the codes after the install? Injectors can be a known problem area with diagnosing misfire codes. If it does come back you'll want to do a compression/leak down test. If it's running much smoother/better now it's probably a good bet to say you solved your issue. Just keep driving it and see if anything changes.
888.280.7799 | 6am - 5pm PST
tylersavage
Jan 29, 2016 08:48 AM
Promius
Jan 21, 2016 12:57 PM
Jorge Perez
Jan 15, 2016 09:38 AM
Jan 6, 2016 02:20 PM
micksid
12
Jan 2, 2016 06:45 AM
