Its for a 2006 mini cooper s. i got one of those intermittent ps pump failure. sometimes it goes out for a few seconds, but then just a few days ago it was gone for a day then suddenly came back to life. I have decided to replace it anyways.
I found a replacement pump (Dorman 599-950). It says that it is applciable to 2006 mini cooper but also says that it replaces OE# 324267100 only.
Does anyone know what this means? What is the OE # for? Should I be concerned about this stipulation? I just want to make sure that this part is compatible to my car before ordering.
32426767100 is the older part number, 32416778424 is a newer parts number, 32416778425 is the newest. See below for all the info and what to check. If you need a P/S pump its linked below. Also you are an 06' so you will be out of the recall tears for the P/S pump and Fan.
Check to see if its the pump, fan, or the wire itself first. Also do you have low P/S fluid ? If the lines leak and there is low or no fluid you will loose Power steering, might just be the lines. Check the reservoir and cap with level.
Yea, its just a quick check to make sure the main plug did knot com undone on the top of the p/s pump. people sometimes break those clips unplugging the harness to do the LCAB or drop the sub-frame for other repairs, its just a quick check before you go into major repairs/
