R50/53 FLywheel bolt pattern/circle ?
Does anyone have this spec ?
or at bare minimum measure it for me ?
I believe they are the same but for an MCS (R53)
Not sure what you are asking for - and not many people have access to their flywheel to measure anything on it...
What are you trying to figure out?
Well i know the flywheel has 8 bolts, so the measurement would be from center of one bolt straight through the center of the flywheel to the center of the adjacent bolt hole.
i need this measurement for a possible rwd project where i wont be using the MCS flywheel, so i need to be able to have my machine shop drill this bolt pattern on a different flywheel.
Well i know the flywheel has 8 bolts, so the measurement would be from center of one bolt straight through the center of the flywheel to the center of the adjacent bolt hole. i need this measurement for a possible rwd project where i wont be using the MCS flywheel, so i need to be able to have my machine shop drill this bolt pattern on a different flywheel.
IIRC, the crank/flywheel holes are not uniform. That is, the holes only line up one specific way. So if you're thinking of turning and drilling your own part, you'd best get a flywheel or crank to use as a template.
Rennfahrer555
General Discussion
248
Apr 25, 2016 12:49 PM
