R50/53 ATI pulley does the OEM puller work?
Old Aug 2, 2015 | 11:52 AM
Nicefeet's Avatar
Nicefeet
I need to change the timing cover gasket because it's seeping at random times. Can I use the OEM puller that I already have to remove the ATI crank pulley?
Old Aug 2, 2015 | 12:32 PM
David.R53's Avatar
David.R53
I had a MINI specific puller and it didn't fit the ATI. My generic (harbor freight) puller fit fine.
I had to write to ATI for this part - the screws are in groups of three. Remove the center screws and use those holes for the puller.
Old Aug 2, 2015 | 07:54 PM
Nicefeet's Avatar
Nicefeet
I had this strange feeling it would not work, so that's good to know.
I got an order in for a OTC harmomic balanced puller and Snap-on the IP40 Torx socket to remove the three bolts.
Old Aug 10, 2015 | 12:53 PM
crazyworld's Avatar
crazyworld
That's right, you'll have to pull out the 3 protruding bolts that take a 5/16" 12 pt socket (8mm socket should fit even better and you may already have one laying around). The holes will then accept a 5/16"x18 bolt. The puller kit I was using had bolts that were 5/16"x18x2" and the short (4") push rod was a tad too short even though it seemed like it might work (it didn't) so I used the long (5 1/2") one.
W0TM8
Dec 19, 2019 07:50 AM
blackie
Oct 2, 2015 07:41 PM
blackie
Sep 2, 2015 09:16 PM
blackie
Aug 23, 2015 08:44 PM
FLYM1N1
Aug 16, 2015 01:15 PM
