R50/53 Battery Indicator Lighting
Old Jul 9, 2015 | 03:53 AM
slide mini's Avatar
slide mini
Hello every body
this is my first post in this nice forums
i have a Mini Cooper R50 w10 2003
the problem now with the battery indicator lighting & Alternator not charging
I replaced the Alternator
I replaced The Battery with New one
i used my autel scanner
there is one fault in instrument cluster says:
KOMBI control module fault
Need your help pls
& thanks Every Body
Old Jul 9, 2015 | 09:10 AM
ZippyNH's Avatar
ZippyNH
Check your fuses....think it is a 5 amp one...forget which one..
The alternator requires a "Field" current...a small input it amplifies to make power... When this 5 amp fuse is blown, even a new alternator will not help (that is the technical difference between an alternator and a older style generator, a generator creates us own field, but cannot produce full output at low rpms, hence why many classic cars have been converted...
The double check your grounds....
Old Jul 9, 2015 | 01:06 PM
slide mini's Avatar
slide mini
Thanx dear
I found the wrong
It's with the alternator power cable loss
Thnx for your reply
Old Jul 9, 2015 | 01:14 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Nevermind! Didn't see your post above!
Glad you figured it out.
888.280.7799 | 6am - 5pm PST
scottrn
Aug 22, 2015 07:26 PM
missinmyjeep
Aug 22, 2015 07:13 PM
Lschneider
Aug 21, 2015 02:21 AM
Herleman
Aug 16, 2015 06:41 PM
