R50/53 Potential Air Leak or Failing BPV
Old Jul 3, 2015 | 06:13 AM
AU_Mini's Avatar
AU_Mini
Hello Ladies and Gents,
So I know there are numerous threads out about air leaks and bad mpgs, and I have read a good number of them but none seem to be the same.
The issue: At idle, I can hear a sucking sound which seems to be coming from my IC. It is concentrated on the right side of the IC and sounds almost just like a CAI, but the sound seems to decrease as you move away from that area. I'm not getting any dumby lights or throwing any codes. The car seemingly drives fine although I have nothing to compare it to.
Within the last couple days, I have noticed that as I'm cruising down the interstate(75~80 mph) I see the mileage range rapidly falling. I dropped almost three miles within ~20 secs, with the cruise set.
I've been told to check for air/vacuum leaks but I would think if I had a leak, I would be thrown into limp mode or see a CEL, especially with this being a FI motor. I'm beginning to think it could be the BPV, as the car has ~128k on the clock.
Any help would be gladly appreciated. Thanks in advance
Old Jul 3, 2015 | 10:58 AM
ZippyNH's Avatar
ZippyNH
Have you taken off the IC too check the boots?
4 torix bolts...about a 4 minute job...
The rubber boots split and tear with age as they get brittle...
A failed IC is pretty rare, but possible.
Old Jul 3, 2015 | 12:54 PM
AU_Mini's Avatar
AU_Mini
I haven't fully inspected the driver side one, but I did spray them down with carb cleaner to see if it would cause a change in idle. I'm going to get a friend to help me attempt to smoke test it later on today.
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
Etrain
16
Aug 5, 2024 04:37 AM
woodstudio
Mar 15, 2020 08:28 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
Indimanic
Aug 19, 2015 11:08 AM
