R50/53 R53 Supercharger Apart, what else to change?
Old Jul 29, 2014 | 12:38 PM
  #26
tragedybysyntax's Avatar
tragedybysyntax
curious about needing the thermostat honestly now that i realize it... See i understand that if it stays open, i wont get any heat in the car.. if it stays closed the car will overheat. Now what i was getting was when i would turn the car off... the radiator fan would kick on for about a minute after i locked the car and then would go off but I was wondering if that was either A:resistor on the radiator fan or B:Since the Supercharger was shot and the water pump wasnt working 100% efficiently if THAT was why the radiator fan was kicking on after i was driving. Can anybody chime in on that little bit of nugget?
Old Jul 29, 2014 | 12:52 PM
  #27
miles_miles7's Avatar
miles_miles7
Since the front end is off for the supercharger its a a good time to do the RESISTOR MOD. Most likely the oem resistor malfunctioning, known to corrode and lost contact.
If its the thermostat you can easily replace it by removing the intercooler and airbox out of the way. To be honest why not just replace the thermostat too if you think its bad.
Old Jul 29, 2014 | 03:41 PM
  #28
ACallahan's Avatar
ACallahan
Might consider these plugs, they cost a bit more cabbage but have heard and experienced excellent results with them.
http://www.sneed4speed.com/r53-mini-...4-brisk-lgs-t/
Old Jul 29, 2014 | 04:09 PM
  #29
tragedybysyntax
but they only sell them for the jcw temperature.. would that be okay for the 17%? i'm tempted to try them
Old Jul 30, 2014 | 05:52 AM
  #30
tragedybysyntax
So, I ordered the sneed plugs, giant WMW order and the tensioner from amazon.... hopefully at least one of the 3 orders shows up before the weekend so I can get started.
I didn notice last night that the idler pulley and tensioner pulley were both covered in oil which explains the squeal I would get from taking off from a light. It APPEARS that the seal on the supercharger let go and the oil ran out of it onto the pulleys. HOPEFULLY i can keep the oil off of the pulleys with the rebuild
Old Jul 30, 2014 | 06:16 AM
  #31
Grizld700's Avatar
Grizld700
If there was ever any overheating at all or if your water pump wasn't working well, always replace the thermostat. Its been comprimised. Even if the cooling fan resistor mod helps with the fan cycling issue, replace that thermostat. Save yourself future headache and possible overheating issues.
Old Jul 30, 2014 | 07:05 AM
  #32
tragedybysyntax
Yup! I grabbed a thermostat as well!
Old Jul 30, 2014 | 07:28 AM
  #33
Grizld700's Avatar
Grizld700
Old Aug 9, 2014 | 09:16 AM
  #34
tragedybysyntax
So I have the bpv setting here.. small hose seems stretched and
not sealing well so
I'll have to replace that.... how do I take the bpv apart to a) adjust it so it closes all the way and b) adjust the spring? link somewheres?
Old Aug 9, 2014 | 10:47 AM
  #35
miles_miles7
Carefully pry open the tabs that holds the spring housing together, very careful. Once open just spread the spring as i told you earlier.
As far as adjusting the flapper valve just back off the hex stopper screw, but, first loosen the lock nut. Adjust screw until the flapper valve just fully close all the way. If the lock screw is locktite use something to loosen the locktite.
Old Aug 10, 2014 | 03:40 PM
  #36
tragedybysyntax
K, i'm still waiting on my tensioner to come in (tuesday) so in the mean time i'm just doing the other odd stuff. Replaced the plugs with BRISKS! Installed the idler pulley, bolting up the water pump and supercharger tonight as well as the Crank Position sensor oring. NOW, i have brand new oil in the mini.. (2 days before i parked it to tear down!) so am i screwed since i have to pull the sensor out or am I okay and wont leak oil all over the place? you see my worry? haha
Old Aug 11, 2014 | 06:55 AM
  #37
tragedybysyntax
anybody?
Old Aug 11, 2014 | 06:59 AM
  #38
miles_miles7
You are okay as the sensor seats higher than the oil level.
Old Aug 11, 2014 | 08:03 AM
  #39
jamez's Avatar
jamez
and even if it wasn't you'd just have to capture the oil in a clean catch basin and put it back in once the project was done - just don't forget
Old Aug 11, 2014 | 09:48 PM
  #40
RogueMini's Avatar
RogueMini
Like Miles said:pulling off the CPS will not release any oil. Clean the hole in the block so that there is no chance of getting any debris on the new o-ring when you put it back in. I put a thin film of oil on the o-ring so it would slide in easy and not risk scratching or tearing the new o-ring. I know all this sounds like overkill, but the CPS is super prone to leaking, and i hate oil leaks! Some people will put gasket sealer on it too (rather than smearing it with oil).
You know you have to get the car tuned with a 17%, and 550s, right?
Old Aug 12, 2014 | 12:36 AM
  #41
miles_miles7
With 17% pulley tune is not needed, but will benefit
550cc yes, they are not drop in and go to your favorite drive thru.
With OP's mod he's ok with factory injectors.
Make sure your new plugs are one step colder because of your smaller pulley.
Old Aug 12, 2014 | 07:53 AM
  #42
RogueMini's Avatar
RogueMini
with a 15%, tune not required. 17% not required if you are a big fan of pinging under load at >5000rpm. you can't hear it due to the anti-knock system, but it is there. 17%-ers will be very happy with a tune... it will get you another 10-12 hp.
Old Aug 12, 2014 | 10:01 AM
  #43
miles_miles7
Um mm did not know that.
How did you confirm the pinging?
Old Aug 12, 2014 | 01:00 PM
  #44
tragedybysyntax
Oh hey you guys didnt mention I had to raise the motor out of the car to get to the fkn tensioner! lol.... It's on a block of wood as we speak tho and the engine mount is removed (curious if i should be replacing the mounts while i'm in here?) anyway... tensioner came in today so when I get home, i'm at least getting that sucker on there! Tomorrow i'll get to bolting up the supercharger / water pump.
Another question... bypass pressure valve i'm working on modifying to close and with more spring tension.... however, what is the little valve box on the drivers side that opens / closes like the BPV? I ask because it seems as tho it doesnt close all the way either and the inside of it was really gross with oily gunk (all cleaned now but... grosssss)
Old Aug 12, 2014 | 01:19 PM
  #45
miles_miles7
Thats your electronic throttle valve, don't mess with that other than cleaning it.
Old Aug 12, 2014 | 01:56 PM
  #46
tragedybysyntax
miles miles, thank you so much! For some reason i feel like i'll actually be able to put this mess back together with your help
Kay, heading out to swap tensioners and to sink the motor back into the car... wish a brutha luck!!!
Old Aug 12, 2014 | 03:11 PM
  #47
Shawnnn's Avatar
Shawnnn
Too late now but no need to remove the engine mount. Just loosen the bolt enough to jack the engine up a little to get the tensioner out.
Old Aug 12, 2014 | 03:19 PM
  #48
tragedybysyntax
SO.. it looks really dried out and the inside is bone dry... replace the upper mount most likely? If so.. with which one do you guys suggest?
Old Aug 12, 2014 | 07:51 PM
  #49
RogueMini's Avatar
RogueMini
Tuner could see it on his scope while he was dialing it in; had to pull out a bunch of timing advance to get it to stop, then could adjust the a/f ratio to get it to run correctly with the 17. Said the extra boost from the 17% was why it was pinging.
My mechanic also was warned about using a 17% after the fact (my fault, i should have asked him first before installing it), but it is all dialed in now, and runs awesome.
Disclaimer: i dont have the experience to claim that all cars with a pully >15% will have detonation issues, but mine sure did. I'm just happy i had it addressed on my R53.
Old Aug 12, 2014 | 08:25 PM
  #50
miles_miles7
Nice to know and thanks.
BTW, which tuning software did your tuner used?
