R50/53 Clutch Arm Pin Removal
Old Jun 12, 2014 | 11:24 AM
tonkyman's Avatar
tonkyman
The clutch arm on my 2002 R50 broke one of the fork arms so the clutch would never completely disengage. When I tore it all down I found that the clutch fork is welded on to the shaft and not bolted like the newer models.
I ordered a new clutch arm and pin so I can replace it. The external arm that the slave cylinder pushes against is held on the shaft by what Mini calls an "anti-rattle" pin. I've tried every way I can think of to remove this pin with no luck. I finally drilled it out but even then the arm would not come off the shaft. Since I didn't need the "broken" arm and shaft I just cut it off.
My question is.... what is the proper procedure for removing and re-installing this pin and arm? The later models I worked on did not require you to remove that arm to get the shaft out of the transmission because the throw-out fork unbolts from the shaft and you just pull it straight out. I was not prepared for a welded throw-out fork. I'm sure BMW has some fancy "special tool" for the job. The arm I'm talking about is on top and to the left in the second picture below. That bad boy is on there really tight.
Thanks,
Tony T
Attached Thumbnails Clutch Arm Pin Removal-2014-06-07-14.24.57.jpg   Clutch Arm Pin Removal-2014-06-07-14.25.58.jpg
Old Jul 16, 2014 | 04:50 PM
JJGreer's Avatar
JJGreer
Me either
I bought the plastic bushings that go on the shaft. Got the bottom in fine but like you I needed to pull the arm off to get the top bushing out. I hammered and punch. Not even a budge. Figured it's "rust welded" in. I gave up and left the old top bushing in. I feel your pain bro.
Old Jul 16, 2014 | 08:54 PM
tonkyman's Avatar
tonkyman
I found a way to get it apart if I ever have to do it again. Drive or drill the pin out from the bell housing side then use a 2 or 3 jaw puller to pull the arm off. I used a 3 jaw puller and hammer to get the arm off the shaft I had cut. Tighten the puller as tight as you can get it then hit the top of the puller with a heavy hammer.... It popped right off after the second tightening.
Easy breezy!
Tony T
Markbett
Jul 3, 2016 04:28 PM
maestro39
Oct 27, 2015 02:38 PM
greekzilla
Aug 23, 2015 03:44 PM
Getrieben
Aug 15, 2015 09:09 PM
