R50/53 maintenance
Old Apr 16, 2014 | 04:07 PM
  #26
bavmotors's Avatar
bavmotors
+1 on the spare oil drain plug. Already had to replace mine.
Old Apr 16, 2014 | 04:44 PM
  #27
ZippyNH's Avatar
ZippyNH
The OEM plug has a rubber gasket built in....
It is ALEGEDLY a one time use item....but most get 3 or 4 uses from one...
But my advise...
If it shows ANY deformation....to either the rubber ring or the bolt part, chuck it...will be $5 well spent!!
Best suggestion I can give..loosen the oil filter cap...let it sit with it loose for 10 minutes or so...drain the oil...THEN DO THE FILTER...it will likely not drip if you let it drain...
Threading the new filter can be a pain...but if you turn the cap about a half turn backwards, you can feel the threads line up...then tighten....fill...leak check...then 5 miles or so later...CHECK IT AGAIN FOR DRIPS....a split o-ring can drip or flood your floor....
Old Apr 17, 2014 | 11:20 PM
  #28
Kahnfucious's Avatar
Kahnfucious
Yup..this is the only really tricky part. I split my o-ring last weekend..sucked a lot. Lost 0.5 quarts on startup. It was scary but I knew what it was instantly.
Sep 10, 2019 09:22 PM
vulkandino
Oct 31, 2015 08:29 PM
pkillur
Tires, Wheels, & Brakes
Oct 1, 2015 03:59 AM
Sep 10, 2015 11:55 AM
ronn
Sep 9, 2015 07:12 PM
