R50/53 '02 R50 Rt. Window kaput....
I don't think that there is an actual test, could be the regulator or the motor. The Fonzie method is where you give it a bang above the door speaker,that's were the motor is, this should wake it up, if it does that means that the motor may be at fault..
+1 on the fonzie method , then if it fails again it on its way out. You have to determine if its just the motor or a snag in the window regulator , get behind the door panels and check the cables , linkage and the motor connection. Also its good to check the toggle bank in the center to make sure the plug in the back its clipped in and secure , if both windows don't work the plug might have came out.
Here is the diagram to help:
Window Electric Motor - Front Left -6/2005
http://www.ecstuning.com/Search/SiteSearch/67626955875/
Window Electric Motor - Front Right ( passenger ) Part # 67626955876 -6/2005
http://www.ecstuning.com/Search/SiteSearch/67626955876/
And the window regulators.
Window Regulator - Front Left ( driver ) Part # 51337039451 -6/2005
http://www.ecstuning.com/Search/SiteSearch/51337039451/
Window Regulator - Front Right ( passenger side ) Part # 51337039452 -6/2005
http://www.ecstuning.com/Search/SiteSearch/51337039452/
Definitely go with the fonzie. I did on my '04 R50 probably 4 or 5 times over the 4 years i had it. I disagree that it indicates something is failing; after smacking it, it would work fine for many months. The window motor just sticks sometimes.
If it's the motor, try the fix on this link:
https://www.northamericanmotoring.co...-fix-free.html
It worked for mine, and didn't cost a penny.
Supertractor3
Apr 7, 2017 11:16 AM
Moshu-Clubman
R55 :: Clubman Talk (2008+)
Jul 13, 2016 08:54 AM
Sep 10, 2015 01:50 PM
Sep 10, 2015 01:48 PM
