R50/53 Bloody Mary - rusEfi DIY ECU testbed
Old Mar 29, 2014 | 07:28 PM
russian2's Avatar
russian2
I would like to introduce Bloody Mary - that's a red R50 which would the second testbed for my DIY ECU project.
Here she comes:
So yes, I am a bit crazy because I am developing an DIY ECU in spare time. I've got some progress on the first test vehicle which is an older, much simpler car - and now I am starting to look into the Mini. First step would be making an ECU harness so that I can put the ECU on the passenger seat and sniff what's going on in these wires.
The 121 pin ECU connector is pretty popular, I have the same connector on my Nissan truck, and the same connector is used by Korean cars which are already waiting for me at junk yards - so, Hyundai would help with raw materials:
This Hackaday article gives an idea of where all this is right now.
Old Mar 30, 2014 | 06:44 PM
russian2's Avatar
russian2
It was naive of me to assume that all 121 pins connectors are compatible :( They are not. On this picture both connectors are made by AMP, but they are different kinds :(
Mini connector is compatible with IV gen Jetta VR6 - plenty of these in junk yards now. Mini connector is not compatible with Hyundai.
Old Mar 31, 2014 | 05:28 AM
Saltysalt's Avatar
Saltysalt
oh interesting, time for a vr6 swap =)
Old Apr 1, 2014 | 04:30 AM
lionrampant's Avatar
lionrampant
I'm curious to see what you find. Please don't stop posting! And worst of all don't let anyone discourage you because you are doing something different.
Old Apr 1, 2014 | 11:39 AM
slomofo's Avatar
slomofo
A very ambitious project indeed. I have a couple questions though.
1. Why do you need a connector that connects to the factory ECU if you are getting rid of that ECU with your own. Don't you need a connector that goes to the factory harness so that you can get the signal wires from the various sensors that you need to intercept in order to make your stand-alone system work?
2. Why no Megasquirt? If you want a non-vehicle specific raw application ECU's with tons of options, they've already got this covered.
I may not see the point of this and if I'm missing it, my apologies.
Old Apr 1, 2014 | 11:51 AM
russian2's Avatar
russian2
#1 - the connector: for the research phase I need to sniff what's going on while the engine is actually running. While technically I can cut the existing harness open, I'd rather take a less intrusive path - I am putting a T-shaped harness extension in between the stock harness and stock ECU. As a matter of fact, at some point I would have TWO ecus connected to the vehicle - with half of the wires going to the stock ECU and half of the wired going to my ECU. So, first phase is a plain harness to confirm which wires are less important. Next I cut the harness and build the T-junction. I hope it would start making more sense while I move forward. You can check this thread - http://rusefi.com/forum/viewtopic.php?f=4&t=454 - for the breakout board.
#2 https://www.kickstarter.com/projects...ject_faq_85742 :
Q: Isn't Megasquirt already offering open source customizable ECU's?
A: No, Megasquirt is offering a closed-source customizable ECU. I believe MS used to be 'open source but not free' (their license requires use of their authentic hardware). People were confusing 'open' for 'free' so MS had to switch to closed-source. rusEfi is a GPL open-source.
Old Apr 1, 2014 | 11:58 AM
slomofo's Avatar
slomofo
Andrey,
This makes more sense to me now. You are developing an ECU that you can have completely open access to mapping for all different applications available. Once the ECU is purchased, the maps are freely shared. Ambitious but you seem to have the right ideas.
Very cool!
Keep up the hard work.
Old Apr 4, 2014 | 06:54 PM
russian2's Avatar
russian2
I am starting with the smaller 40p connector. I've wired
82/1 Acceleration Pedal
83/2 Acceleration Pedal
86/5 Acceleration Pedal
87/6 Acceleration Pedal Ground
105/24 Fuel Pump
107/26 Acceleration Pedal
108/27 Acceleration Pedal
114/33 ECU Ground
115/34 ECU Ground
118/37 Fuel Pump
120/39 +12V
121/40 Power +12V all times
but it would not start. So I am back to the wiring diagram, apparently it needs more wires to be in place. Clutch switch module maybe?
I've got the diagram on my http://rusefi.com/wiki/index.php?tit...ni_Cooper_2003 wiki
Old Apr 4, 2014 | 08:59 PM
russian2's Avatar
russian2
I've missed two important wires.
Now, with addition of
85/4 Clutch switch
97/16 From main relay
106/25 Anti-theft system
The car starts & revs via my harness extension. Next step - same thing for the larger connector.
Old Apr 5, 2014 | 05:40 AM
RA082324's Avatar
RA082324
very interesting. subscribed.
Old Apr 5, 2014 | 06:15 AM
DSKSMini's Avatar
DSKSMini
Saw your kikstarter project. Good to see you on NAM. Subscribed!
Old Apr 8, 2014 | 07:25 PM
russian2's Avatar
russian2
Mini Cooper: ECU on a minimalistic harness extension - YouTube
"> Mini Cooper: ECU on a minimalistic harness extension - YouTube
" type="application/x-shockwave-flash" width="425" height="350">
Got the minimalistic harness extension: no coolant temp, no CAN. While the car starts it is surely confused, but that's OK for my purposes.
Next step would be to cut some of the wires, make a T-junction and sniff what's going on in the wires.
PS: did I mention https://www.kickstarter.com/projects...-unit-ecu-firm?
Old Apr 9, 2014 | 08:21 PM
russian2's Avatar
russian2
The whole point of this harness extension is that I can sit on the driver seat and have access to the ECU wires. I've started routing the most interesting wires through http://rusefi.com/forum/viewtopic.php?f=4&t=454 - like this:
Multimeter shows ~2.5v in both wires while the car is running, so it's safe to connect a cheap logic analyzer. That's what we see:
Crank signal is on top and cam is on the bottom. Crank is a skipped tooth wheel with one wide teeth, cam is just a simple 47% wave.
Does anyone know where TDC #1 is? Has anyone noticed if the tooth wheel is visible any angle? Maybe from the bottom? Need to stick a pencil into a spark hole and see where the wheel would be.
bahman
Feb 14, 2016 10:29 AM
mni928
Nov 9, 2015 07:38 PM
M7Speed
Oct 1, 2015 07:05 AM
genik
Cooper (non S)
Sep 25, 2015 02:46 PM
Sep 25, 2015 12:32 PM
