R50/53 SS Brake Lines vs Brass Guide Bushings
Old Feb 6, 2014 | 08:54 PM
Mib4840's Avatar
Mib4840
I do my modifications a little at a time so I was wondering which I will get better or more noticeable results from, a set of Stainless Steel Brake Lines or a set of Brass Guide Bushings for the calipers? Or is this not even a comparison?
Old Feb 7, 2014 | 04:48 AM
Saltysalt's Avatar
Saltysalt
i would say the stainless lines, since if the rubber lines are old, they will still stretch rendering the brass guides useless
Old Feb 7, 2014 | 05:01 AM
astroBlackMetallic_Mini's Avatar
i think with those brass guides, you have to grease them regularly... so be aware of that!
Old Feb 7, 2014 | 06:13 AM
daonlyillwiz's Avatar
daonlyillwiz
Stainless lines, thats the way to go since it stiffens the entire line vs the brass guides where it only focuses on a single point.
Thing about it, the reason you want to upgrade to stainless steel lines is to get better braking, and the reason the rubber lines are no good is because they flex when the brakes are applied because of the internal pressure. With the SS lines you dont have that flex.
Old Feb 7, 2014 | 07:31 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You will notice the brake stiffening bushings more than the lines. Both are good improvements but the bushings seem to be easier to notice.
Yes you should grease them at least once a year.
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
minimofo
Apr 4, 2016 07:36 PM
Mini7
Feb 2, 2016 07:52 PM
minimofo
Dec 26, 2015 11:45 AM
