R50/53 Heater issue and "overheating"
Old Jan 10, 2014 | 02:48 PM
MIKE FROM SM's Avatar
MIKE FROM SM
My wife has an 03 Cooper S. It "overheats" randomly. I recently put a new thermostat in thinking that was the issue. I can have it run all day and be okay. I drove the thing aroung for 2 days with heater on, then ac on with no issues. I leave town and it overheats on her. The heater won't work and the temp will climb and push coolant out the overflow. The engine itself wasn't hot. I can shut the engine off and start it and it will be back to normal. Playing with the heater controls seems to set it off. I tried bleeding it and seem to have gotten all the air out. I was not able to access the thermostat bleed screw though.
Old Jan 11, 2014 | 03:50 AM
ZippyNH's Avatar
ZippyNH
Finish bleeding it....it has not been done...you never opened the thermostat bleed valve....
Then hope it works....
Similar sounds to a failing head gasket.... But overheating can also CAUSE a failed head gasket...
Old Jan 11, 2014 | 07:09 PM
Debi's Coop S's Avatar
Debi's Coop S
That was my first thought, blown head gasket. Probably need to do a compression test and coolant pressure test.
battlehawk_mini
Mar 5, 2021 06:15 AM
W0TM8
Dec 19, 2019 07:50 AM
rtk90
Aug 29, 2019 09:08 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
tylewis
Sep 6, 2015 01:07 PM
