R50/53 Brake squeal while braking
Old Oct 28, 2013 | 09:55 AM
locksleyr53's Avatar
locksleyr53
It started a couple of weeks ago, I press the pedal and the front right (I believe) squeals and it varies with pedal pressure. I figured it was getting close to new brakes but I just pulled the front wheels off and there is enough material there, about 1/4". I know that squeal can be caused by loose pad material but nothing seems to be shifted in there.
Old Oct 28, 2013 | 10:44 AM
gnuse's Avatar
gnuse
Likely glazing on surface of pads. Sand pad material on a flat surface, make sure isolator material is intact on back of pad next to piston and try that. It worked on mine.
Old Oct 28, 2013 | 01:25 PM
ZippyNH's Avatar
ZippyNH
If the pad meteral is thinner than the backing plate, change the Pad...
If the pad is groved, with a lip at the edge, you might be hearing the metal pad backer touch the lip that now sticks up a bit....
Old Oct 28, 2013 | 04:47 PM
locksleyr53
I'll give that a shot and let you know, thanks
The pad material is defiantly thicker than the backing.
patsum
26
May 29, 2021 06:29 PM
Sep 10, 2015 10:52 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
